This is a discussion on has anyone - VAG-COM powersteering change within the Fabia I forums, part of the Skoda Model Discussion Area category; I was wondering if anyone had altered the "weight" of their powersteering using VAG- COM and if it was anybetter ...
| Briskodian Join Date: Jun 2005 Location: midlands
| I was wondering if anyone had altered the "weight" of their powersteering using VAG- COM and if it was anybetter ? , as i find my VRS sterring to be uber light. |
| I did this on a couple of cars, but they were all set at the heaviest setting (which was still a bit too light).... worth double checking, but don't get your hope up ![]() Chris
| Changed it on mine a couple of times.
__________________ John Take away the poor damping, inadequate bushes, heavy diesel lump and spongy brakes its not a bad warm hatch |
| Briskodian Join Date: Oct 2006 Location: Still in Suffolk
| Changed the weight on mine to the vRS settings seemed to make a difference, bit more meatier feel now. |
| Hardcore Join Date: Feb 2006 Location: Bahrain
| changed it - but then changed it back - guess I've gotten used to light steering wheels...
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| I gotta get this done, do you know what dealers charge for it? cos if i dont like it, i dont wanna p**s em off asking em to put it back. |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
| find someone with vag com, dealers will charge a fortune, esp if you dont like it and want it back to where it was at. What is the VRS setting on the power steering (via vag com)? |
