This is a discussion on High pitched whistle on start up within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi all. Just a quick one.... I have an 04 VRS with 32k miles on it, it has a dragon ...
| Briskodian Join Date: Jun 2007 Location: Brecon/ Cardiff
| Hi all. Just a quick one.... I have an 04 VRS with 32k miles on it, it has a dragon box fitted for about the past 3k miles. Upon startup I get a high pitched whistling noise as it idles, its not very loud, but is noticable, when I apply the throttle it goes away then after a few moments back at idle it returns. If I go for a drive and the engine warms up, then I stop and leave it at idle for a few moments it does not do it? I have scanned the engine for fault codes using the free version of VAG COM and nothing has come up. Any ideas?
__________________ '04 Fabia VRS - 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Boost + Volt Gauge, Window Tints |
| Nuts Join Date: Nov 2006 Location: Greater Manchester
| They all do this. I posted the same question a good few months ago - I forget the answer ![]()
__________________ "Stupidity, if left untreated, is self-correcting." - Heinlein |
| Briskodian Join Date: Jul 2007 Location: Sofia, Bulgaria
| Had a similar problem with my previous Astra once or twice - the alternator belt was damp and made horrible noise. Drove it a bit and it all went away.
__________________ |
| Moving Stables Join Date: Dec 2006
| The noise is normal, its the egr valve opening that causes the whistle. The turbo can be heard more and this is just the turbo spinning noise. Really is normal nothing to worry about, i think its quite cool tbh, sounds like a kettle whistling ![]()
__________________ Bored of the volvo already |
| Haha ok. thanks a lot for the reassurance guys.
