This is a discussion on High revs on start up when engine warm within the Fabia forums, part of the Skoda Model Discussion Area category; Has anyone come across this one before? When I start my 1.9TDI from cold all is absolutely normal - the ...
Pronounced "bris-skoda", a brisk skoda, a Skoda driven in a brisk manner. | Register | FAQ | Members List | Calendar | Mark Forums Read |
| Briskodian Join Date: Aug 2005 Location: South Midlands
| Has anyone come across this one before? When I start my 1.9TDI from cold all is absolutely normal - the engine starts immediately and runs at slightly higher than normal tickover. When I start the engine when at normal working temperature, the engine starts and idles at normal tickover speed. However, at a certain temperature between cold and normal - if I start the engine, it revs instantly to about 3,000 rpm for mabye 1 second and then drops back down to normal idle speed. During this revving, the tappets rattle and I am worried that other damage may be being done before the oil pressure comes up. During this latest spell of hot weather, the engine revved like this on starting after sitting in the sun all day - engine not been running for 8 hours. I guess that the problem is due to a sensor somewhere, starting to show its age - the temperature gauge however, seems to work absolutely normally. Has anyone any ideas of what I might check? Regards Quent |
| Get out the way Join Date: Oct 2007 Location: Bournemouth
| Hi, Mine sits at 900rpm whether cold,normal or hot and never moves either side of it at idle.Check to see if a fault code is showing if you have access to VAGCOM or take to a dealer. Also maybe worth trying the "Cage Mod" as this cures many things.Do a search on here to see how its done Good Luck |
| Briskodian Join Date: Mar 2008 Location: B,Ham
| i get the same sort of thing but mine starts t judder every like 7 seconds? anyone else witness this or had similar problems? |
| Briskodian Join Date: Apr 2007
| Sounds like a fuel fault to me??? |
| Briskodian Join Date: Nov 2005 Location: Longford, Ireland
| Coolant temp sensor is the problem.
__________________ 2008 Race blue 2.0 TFSI vRS, xenons, jumbo box, dual zone, rear electric windows, maxidot, rain sensing wipers and dimming mirror, light assist, rear parking sensors, cruise control, ESP and anti wet ars!e feature.... |
