How can I make a Fabia immovable?
This is a discussion on How can I make a Fabia immovable? within the Fabia I forums, part of the Skoda Model Discussion Area category; My Fabia is going to be staying in he garage for a few days and not coming out to play. ...
Old 04-04-2005, 20:09   #1
Moose's Avatar
Location: I'm a monkey from outer space, woooooooo ahhhhhhhhh hehe hooohaa
Default How can I make a Fabia immovable?
My Fabia is going to be staying in he garage for a few days and not coming out to play. However around my area, garages are easily broken into and the last thing I want is to have it stolen. So, is there anything I can remove easily from the engine bay to keep inside my house that would warrant the car immovable? It has to be easily put back too.
Sunlight Silver MX-5 1.8 Sport
Moose is offline
Old 04-04-2005, 20:12   #2
Manguish's Avatar
Default
Take the wheels off
Manguish is offline
Old 04-04-2005, 20:19   #3
Briskodaholic
Tom_vRS's Avatar
Default
Originally Posted by manguish
Take the wheels off
You keep your wheels in the engine bay? Now that is a mod!
97/R BMW 328i in Boston Green.
<< Clickable for boring info.
My Journal
Tom_vRS is offline
Old 04-04-2005, 20:27   #4
Grant's Avatar
Default
The battery should be easy to take out, but you'd have to reprogram lots of things when you put it back in.
Could take out a few fuses. eg starter motor, fuel pump etc.
Grant is offline
Old 04-04-2005, 20:31   #5
Location: Monday: MK Tuesday: MK Wednesday: MK Thursday: MK Friday: MK/Home Saturday: Home Sunday: In bed ;o)
Default
Take the wheels off
Probably the best idea...
And if you want to be really crafty to find them they have to follow a series of clues
Having a little break, concentrate on the more important things in life, swmbo and my training.
See you soon folks, take care - James
walkie is offline
Old 04-04-2005, 20:37   #6
Manguish's Avatar
Default
Spread across the county
Manguish is offline
Old 04-04-2005, 20:43   #7
DRJ
Default
Problem is that would make the alarm ineffective and hence potentially void any insurance claim
On an MX-5 there's a specific thing people do - but it's not something to be aired in public... I'll PM Richard...
David - Skoda Fabia vRS - October 2004 facelift
DRJ is offline
Old 04-04-2005, 20:46   #8
Decapodian
Dr Zoidberg's Avatar
Default
HT Leads are the easiest.
If you want to make it less obvious what you have done just swap them round a bit
Alex
www.drzoidberg.co.uk
Dr Zoidberg is offline
Old 04-04-2005, 20:53   #9
Mongreller
devonutopia's Avatar
Default
How about remove the steering wheel? Apparently, all you need to do is use a screwdriver in the back (two holes which releases pins - sounds easy but its a b1tch to do...) Then you can leave the airbag bit on the passenger seat, and use a big wrench to remove the steering wheel itself. HTH
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 04-04-2005, 20:56   #10
DRJ
Default
HT Leads are the easiest. If you want to make it less obvious what you have done just swap them round a bit
Richard's car is a Skoda Fabia 1.9TDi Comfort
DRJ is offline
Old 04-04-2005, 21:13   #11
Moose's Avatar
Default
Thanks for the PM David, I'll try when its light. It's in the garage tonight and its all locked up and empty.
Was thinking the same with regards to the HT leads.
What about the item that is under the car, directly under the drivers seat? Remove that?
Moose is offline
Old 04-04-2005, 21:42   #12
Hairy Yeti
Lummox's Avatar
Default
Rich thats a fuel cooler, you dont want to be removing that.
Ideally you want to remove the fuel pump relay, cant for the life of me think where it is on the Fabia though. But remove anything electrical and you may well get a fault code thrown up i'd expect.
Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
Old 04-04-2005, 21:52   #13
helpmedisappear's Avatar
Default
It might sound obvious but does the ignition have a fuse? If it does then remove it!
Martin
Black Magic Fabia vRS
v
helpmedisappear is offline
Old 04-04-2005, 21:55   #14
EddyH's Avatar
Default
How about the key? They're unlikely to start it without that.
EddyH
Audi S8
Audi A3 2.0 TDI Sport
EddyH is offline
Old 04-04-2005, 22:04   #15
Moose's Avatar
Default
So maybe best not to do any fuses etc?
Could well be best to hope and keep checking it I think.
Moose is offline
Old 04-04-2005, 22:07   #16
redbaron's Avatar
Default
would love to see this trick performed on a tdi......
think i would be more inclined to pull the plug out of the ecu...
________________________________________
Some times I just feel like smiling.
redbaron is offline
Old 04-04-2005, 23:00   #17
Escorted Estate
Default
Could put a sign on - it's a Skoda, honest - that should scare most people. Had it been a Briskoda sticker it would be different
WW --->> Project Journal (pic links in first post there)
WW_VRS is offline
Old 04-04-2005, 23:04   #18
Hairy Yeti
Lummox's Avatar
Default
Thats about the most sensable answer ive heard. tbh not many people will get one started now without the key. Just make sure its in a very safe place out of sight.
Lummox is offline
Old 04-04-2005, 23:19   #19
Default
Fuse's on top top of the battery
Etos is offline
Old 04-04-2005, 23:21   #20
Mongreller
Default
Anything wrong with just leaving the ECU inside the house somewhere hidden? Its dead easy to unplug (when there's no strut brace in the way ) and refitting is about as easy too.
Anyway, in this day and age of immobilisers and stuff, no-one 'll break in for your car, it'll be for the audio or something they spot, so keep nothing in view inside the car, especially audio/loose change/anything with remotely any value that can be had with a quick smash n grab.
