40,637 Members 1,519,407 Posts
I/C Waterspray
This is a discussion on I/C Waterspray within the Fabia I forums, part of the Skoda Model Discussion Area category; I'm going to invest in an I/C waterspray instead of going full on and getting the Seat Sport FMIC as ...
Old 30-01-2005, 20:49   #1
HellFire's Avatar
Members Car: Skoda Fabia vRS
I/C Waterspray
I'm going to invest in an I/C waterspray instead of going full on and getting the Seat Sport FMIC as I believe there will be still good benefits to be gained in the hot summer days & maybe winter days if I drive the car hard.
I'm purchasing the unit from Canward Racing Technologies (www.canward.co.uk) - I've been recommended to get the 3 misting nozzle system and i'm also going for the adjustable boost pressure activation switch, which will then activate the system automatically - can be set between 12-24psi as it works of the turbo's boost pressure.
Ok, so what do you all think?
Metro Blue '06' 5 Door Astra 1.8 SRi
HellFire is offline
Old 30-01-2005, 21:00   #2
VT5
Members Car: Fabia vRS
Would be very interested to see how you get on.
Considering new FMIC here before summer arrives.
Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion
Now: 2008 Audi A3 Sportback TDI
FabiaTDi is offline
Old 30-01-2005, 21:04   #3
Partner
Lummox's Avatar
Images: 2
I have been in touch with them myself, very friendly outfit I must day. They are going to be doing me a kit for my FMIC when its ready.
www.unit18.co.uk
Lummox is offline
Old 30-01-2005, 21:15   #4
Dinosaur
TaviaRS's Avatar
Members Car: Merc E class & SLK
I had one on my Octy - excellent unit. Got it from www.autospeed.com Easy to install and works really well, highly recommend
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
Old 30-01-2005, 21:31   #5
HellFire's Avatar
My only concern is unless I specify an external resovoir for water then then it's going to take it from my washer bottle meaning I can never put washer fluid in if I want to wash my windows!
HellFire is offline
Old 30-01-2005, 21:35   #6
Dinosaur
TaviaRS's Avatar
Erm, I ran methanol or a high alcohol content screen wash, good cooling and it cleared the screen a treat
With the one I had, you could either switch it off or change the kick in point.
TaviaRS is offline
Old 30-01-2005, 22:15   #7
130bhp
Josh_PoloGTi's Avatar
I have also contacted these guys and I'm planning on buying one of their kits before my trip to Austria.
Originally Posted by Goochie View Post
Some say that if you break him in half he has a hard white centre with red writing though it.
Some say this writing says "JBS Auto Designs"
All we know is, that he's called The Josh!
Josh_PoloGTi is offline
Old 30-01-2005, 22:48   #8
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
So, lemme get this straight? You can get an FMIC which is an improvement on the one tucked in under the bumper, AND using a water spray mist thingie is an improvement ON TOP of this?
devonutopia is offline
Old 30-01-2005, 22:55   #9
Dinosaur
TaviaRS's Avatar
Yep
TaviaRS is offline
Old 30-01-2005, 23:00   #10
Location: Monday: MK Tuesday: MK Wednesday: MK Thursday: MK Friday: MK/Home Saturday: Home Sunday: In bed ;o)
Members Car: BMW 120D M-Sport
Do you manually spray this or is it automatic?
Having a little break, concentrate on the more important things in life, swmbo and my training.
See you soon folks, take care - James
walkie is offline
Old 30-01-2005, 23:06   #11
HellFire's Avatar
Either, the auto one I belive has a switch to turn it on, until you turn it off (it chooses when it needs spraying by the boost on the turbo), or you can go for the manual which also has a switch where in hot weather (or anytime you like really), it sprays the IC for 10 seconds which is enough to dissapate heat for 5 mins of full throttle driving, but you choose when it does it and it's not automatic. I thought a diesel turbo only ran at 1.7 bar after a remap though, so i'd probably opt for the manual one and then atleast if it goes wrong it's me who's controlling it
HellFire is offline
Old 30-01-2005, 23:22   #12
Mongreller
Images: 5
Originally Posted by TaviaRS
Yep
Its great when one word and a smiley says it all!
Get my answerphone message Doesn't matter now though.
Old 31-01-2005, 07:33   #13
Dinosaur
TaviaRS's Avatar
Got it last night.
Not sure if the autospeed one will work with a TDI (I know it works with petrol). Works on difference between ambient air temp and intercooler temp, and on injector duty cycle eg you set it to trigger only when when temp difference is >10 degrees c and when injector duty rate is >80%. Will only fire when both conditions are met. Fully adjustable on both parameters.
TaviaRS is offline
Old 13-03-2005, 19:56   #14
130bhp
Hellfire...
Did you ever get one of these?
I still need to measure how long the delivery bar can be (to fit in the little space there is in front of the IC) and I was just thinking that if you've already got one, they could just make me one from your patern...
Old 13-03-2005, 20:28   #15
HellFire's Avatar
I didnt opt for it in the end because I was concerned about a few things such as if it actually worked and in the event of a crash would the crumple zones react in the same way (never saw the unit or had my bumper off but i guess it would have), and also the reliability of the unit & where I would store extra resovoir bottle...
HellFire is offline
Old 13-03-2005, 20:38   #16
130bhp
OK, well I'll buy one and let you know what I think
I'm going to do the TT Arch Liner Vent mod (or a shanty-town diy version of this, which is more likely) in addition to this.
I understand your safety concerns. I would have thought, because it's such a small device, that this can be mounted to the plastic of the actual bumper...
I'll put a full report on once I've fitted it.
Old 13-03-2005, 22:12   #17
DGW
BRISKODA Staff
DGW's Avatar
I would be interested to know which vent you eventually decide to buy. Have you seen the one Adrian (SkodiRS) fitted?
Denis
2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.12mpg...
DGW is offline
Old 13-03-2005, 22:56   #18
GT TDI's Avatar
Members Car: VW Golft GT TDI
Just found this on eBay clicky........
Seb P :drive: Bora Sport TDI 150
GT TDI is offline
Old 13-03-2005, 23:22   #19
steve's Avatar
Members Car:
With a live connection and a washer bottle/motor etc you could make one for a tenner.......OK you will need to operate it by hand but...........
Steve
steve is offline
Similar Threads
Fab Rs I/C water spray? Dan_P Maintenance & Performance 10 31-08-2004 10:45
Fitting IC Waterspray kit wilsonan Maintenance & Performance 4 05-07-2004 16:28
