This is a discussion on Lazy oil warning light ? within the Fabia I forums, part of the Skoda Model Discussion Area category; Just had my 1.4 16v back from local dealer. Whilst he was fixing my rear door seals again (!) told ...
| Briskodian Join Date: Dec 2007
| Just had my 1.4 16v back from local dealer. Whilst he was fixing my rear door seals again (!) told him how it sounds like a diesel - see previous post petrol but not so you would know. He found it was 2 litres below the recommended level. Car had been fully serviced by dealer Nov 2007. Now IF my car is the AUA/B type (think that's right) thats soooo low as to be potentially damaging. It only holds just over 3 litres! He topped it up with 2 litres and the rattle all but went away. Have done nearly 100 miles, all OK still. But why did my Oil warning light NEVER come on? Not once? Having only 33% of the correct amount of oil should have triggered something (quantity/pressure). Also oil warning light self test showed nothing (flashes I believe). I have checked the oil from time to time since having the car 6 months ago, all appeared OK,so I guess I just got unlucky. There is no loss in performance, no smoke during driving or start up. Any ideas welcome. Last edited by BlueSilver; 13-06-2008 at 17:12. Reason: spelling as suspect as oil light :@) |
| UberMod™ Join Date: Feb 2003 Location: Manchester
| When you switch the ignition on but dont start the engine, the oil, battery and brake (handbrake) light should all be on. when you start the engine, only the handbrake warning light should be on. If this is not the case, further investigation should be done.
__________________ ColGod the UberMod ![]() VXR, Gti, ST, Type-R, vRS, Cupra, Shifty... An MPS fears not these things... ![]() ![]() |
| Your car wont have an oil level sensor, you car will still make oil pressure even with a litre of oil in it, however might not make it for long. No excuse for not checking your engine oil at least every fortnight, if the engine oil pressure light does come on it all to late anyhow.
__________________ Unit 18 Automotive Services |
| | #4 | |
| Quote:
I agree, I am used to my previous car being very economical with oil! I will now check the oil at least every 2 weeks, ideally weekly! Very suprised the light won't come on though with just one litre of oil in the engine. It does say that this should happen according to the manual...so suprised to learn there is no oil level sensor for my car...(maybe other variants) Last edited by BlueSilver; 13-06-2008 at 17:11. Reason: tidying text | |
| As the Fabia doesnt fun variable servicing they arent fitted with a sump sensor.
| | #6 | |
| Quote:
Thanks Lummox for that, now I've thought about it guess that's common sense ![]() Last edited by BlueSilver; 13-06-2008 at 19:27. Reason: tidying | |
