This is a discussion on lighting issues within the Fabia I forums, part of the Skoda Model Discussion Area category; hi. I would really appreciate some troubleshooting help with my lights. - I've got a fabia 1.4 16v comfort. My ...
| Briskodian Join Date: Jan 2007
| hi. I would really appreciate some troubleshooting help with my lights. - I've got a fabia 1.4 16v comfort. My passanger side brake light and headlight have both gone at the same time. I really have no idea with cars and just thought it a bit strange. is it likely to be the bulbs, or do you think I might have to fart around changing fuses? if so, where is the fuse box? This car has been nothing but trouble. wish I had kept the old favorit. I would really appreciate your help. Cheers carl |
| Briskodian Join Date: Apr 2006 Location: North East
| Probably just bulbs. The headlight and brake light will be on different fuses anyway. If it was a tail light and side light, then that could have been a fuse.
__________________ My other car is a Porsche.... |
| Briskodian Join Date: Sep 2006 Location: Walsall
| For reference, the fusebox is at the right end of the dash- the door closes against a cover that pulls off. |
| that'ss great thanks. I've just been out to take a look with your advice. I swapped the bulbs round and it worked, so I just need to pick up a new bulb tomorrow. thanks for that one - i appreciate it |
| Briskodian Join Date: Apr 2004
| Good idea to change bulbs on both sides at the same time - they last about same time, so you can expect the others to fail before long. |
