This is a discussion on More problems within the Fabia I forums, part of the Skoda Model Discussion Area category; Just when I thought I was nearly sorted a few other things pop up. Whe starting off the first 3 ...
| Briskodian Join Date: May 2007
| Just when I thought I was nearly sorted a few other things pop up. Whe starting off the first 3 or 4 times that I break I get a grinding noise but after a few stops it disapears never to be heard again until the car has been sat for a while and I set off again. Also in 2nd gear this morning at just under 2.5k revs I had some really bad juddering like it was going to stall. I have had this before a few times could it be missfiring? Any ideas especially with the breaks well what I think is the breaks. |
| Briskodian Join Date: Feb 2007 Location: East Sussex and Sometimes North Yorks. and sometimes in between!
| I have the same on mine with the brakes. Do you have discs all round? I've noticed that when i go out to the car on a morning the discs are discoloured from sitting all night - a slightly rusty tinge to them... after braking a few times this clears all the grime completly and they work fine. I just assumed this was normal.
__________________ Octavia Mk 1 VRS, Black Magic |
| No idea about the discs I have a 2000 1.4MPI? It only started last night got in the car from work was fine and drove 25 miles down the Mway to Preston. Parked up for about 3 hours then when I set off it started after the first few junctions it had gone. When I drove down the Mway on the way it lashed it down and all the time I was parked up so I put it down to a bit of damp and they needed drying off. Then when I got in the car this morning it did it again. |
| Just a quick thought if it is the discs does this mean they are on their way out, It only had service and MOT 3 months ago so I would be very suprised. |
