This is a discussion on New owner with boot release fault. within the Fabia I forums, part of the Skoda Model Discussion Area category; Hello all, have recently purchased a 2000 Fabia and the external boot release has stopped working. The internal lever still ...
| Briskodian Join Date: Mar 2005 Location: N.EAST
| Hello all, have recently purchased a 2000 Fabia and the external boot release has stopped working. The internal lever still works so I think it may be the switch, solenoid or a fuse. Has anyone else had a similar problem or can you point me to the appropriate fuse as I am without an owners manual. Thanks in advance. Tony ![]() |
| | #2 | |
| Quote:
![]() Chris
| Briskodian Join Date: Jan 2004 Location: York
| where is the boot lever :S
__________________ First step to recovery is admitting you have a problem Hi, my name is Mike and I own a Skoda and to top it all off it’s a diesel . |
| Techie Teacher Join Date: Jun 2004 Location: Hertfordshire
| If it's a classic model it was never activated. It depended on having central locking I believe. Certainly my 2000 (X) 1.4 Classic did not have the external release and it was a pain in the neck. It did have the feel of having the release but it just was not there.
__________________ Neil Williams History: Fabia 1.4 8v, Fabia 1.4 16v, Fabia vRS Now driving a Golf Mk5 tdi Teachers click HERE for free resources. |
| Thanks for the help, not sure if it ever worked but it does have the external boot switch which is hidden above the number plate under a rubber guard and I can hear a faint clicking from that which suggests the switch may be ok. Its a comfort version and when I test drove another identical example this external button released the boot solenoid. The internal mechanical lever is on the floor on the right hand side of the drivers seat next to the petrol filler cap release lever. Anyway, I have since checked the fuses and now looks like I may have to get to the switch or solenoid to test. |
| | #6 | |
| Quote:
![]() Chris
