This is a discussion on pd130 engine behaviour within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi all, I was wondering if any of you guys noticed the same engine behaviour on the vrs as I ...
| Briskodian Join Date: Dec 2004
| Hi all, I was wondering if any of you guys noticed the same engine behaviour on the vrs as I do with my 130tdi cordoba. With the car in neutral, very slowly increase the revs, at about 2000rpm i can hear the turbo whistling when it gets to about 2100rpm with the foot held steady the revs oscilate a little maybe by about 25rpm. increasing the revs slowly till 3000rpm the turbo whistle just stops and there is no sign of it after that. Is this normal behaviour for the 130tdi? Any comments greatly appreciated. |
| | #2 | |
| Moving Stables Join Date: Dec 2006
| Quote:
If u want to see for yourself, Pull the vac pip off the egr valve and block it with a bolt. You will see the boosting up and down has gone. But be prepared to erase any fault codes.
__________________ ![]() New ??????? haha I need slippers and a pipe with this one. but it might be a real sleeper ![]() Gone..... 226bhp + 382lbft ![]() Fabia vRS + Stage 2 hybrid now on lowered suspension goes like a missile | |
| OK, so EGR valve is a possibility, The car is a 2006 with only 14k on the clock, quite a low mileage for this to go? Is the whistleing turbo only between 2 and 3k normal also? CHeers |
| Depends how loud the whislting is?
| The whistle is really loud, my previous 150pd toledo never sounded like that, the bit that confuses me is that it just completely switches off at 3k, no gradual change. |
| | #6 | |
| Quote:
My money is still on a faulty egr, do you have any fault codes at all?
| Hi, no fault codes - car seems quite thirsty at the mo anout 400-450 miles per tank, also seems quite slow as well - no smoke at all out of it. |
| Briskodian Join Date: Aug 2007 Location: Liverpool
| 400-450 miles out of a tank is thirsty? I normally get 400 max!
__________________ |
| I said HOT DAMN Join Date: Sep 2006 Location: Normanton, West Yorks
| What size tank is the Cordoba? When my EGR was knackered my mpg was down too, as was the power. Felt like a new car once that was replaced and much better on fuel.
__________________ Silver '04 Fabia vRS. Jabba Custom Remap, Seat Surgeons Leather interior, Whiteline RARB, Cupra Console Bushes |
| | #10 |
| it takes roughly £40 to brim it - Is it likely to be the actual valve or the electrical (solenoid?) that controls it thats on its way out? |
| | #11 | |
| Quote:
They are both about £100. have a look on ebay, theres always one going on there.
| | #12 |
| Yup, then turn it down using VAG-COM to stop it happening again. ![]()
| | #13 |
| Briskodian Join Date: Sep 2007 Location: Hartlepool
| i only get about 400 to a tank |
| | #14 |
| Briskodian Join Date: Jul 2006 Location: milton keynes
| I think that 400 miles to a tank in Vrs is completly normal, thats what i get give or take 30 miles eachway and have done ever since the car was new Maybe 450 on occasional mototrway trips, Thats without the air release filling method Matt
__________________ Black Fabia Vrs, PD160 air intake, Pipercross filter, Aero Wipers, Phillips 80% extra bulbs |
| | #15 |
| Yeah, ive read that a few people have had it turned down, i am wondering if it would be worth cleaning the valve out first? I suppose I would need to find someone in the durham area with a vagcom.. |
