Reducing dive under braking...
This is a discussion on Reducing dive under braking... within the Fabia I forums, part of the Skoda Model Discussion Area category; ...whilst maintaining stock suspension height? How can this be done? I don't really want to fit lowered springs to stiffen ...
Old 15-08-2007, 21:19   #1
*tim*'s Avatar
Question Reducing dive under braking...
How can this be done? I don't really want to fit lowered springs to stiffen the suspension up as I've found the floor on a couple of occasions already
I'm thinking along the lines of Koni FSD's dampers but keeping the stock springs. Anyone know if this would work, and whether the dampers can be fitted to the vRS, some places say they can't but others don't mention (in)compatibility at all
Opinions appreciated.
Tim
*tim* is offline
Old 15-08-2007, 21:20   #2
Briskodiodion
TeflonTom's Avatar
Default Re: Reducing dive under braking...
yeah, it's fine fitting the stock springs to the fsd's
vorsprung durch czechnik
TeflonTom is offline
Old 15-08-2007, 21:22   #3
*tim*'s Avatar
Quick of the mark there Tom. Thanks
Got any experience of how it would drive?
*tim* is offline
Old 15-08-2007, 21:26   #4
Briskodiodion
TeflonTom's Avatar
to be totally truthfull.... no... but however they will definately fit ok, imho the fsd's felt a little strange at first on mine, but once the new springs(i've got koni springs) settled down it now feels a lot better...
the other alternative for you is to use the TDI lowering springs rather than the vrs ones, they have a higher ride height but have the same poundage(stiffness)
Old 15-08-2007, 21:27   #5
Te reduce dive under braking. You should plan ahead and brake earlier. I view braking like the curve of a rugby ball. At first, look way ahead into the distance and see what hazard, junction etc is approaching. Position the vehicle on the road and apply gentle braking, increasing it slighty to slow the vehicle. Once the speed starts to reduce then the amount of pressure needed should be reduced. So once you are almost stopping, reduce the pedal pressure so you dont get that jerk forward most people get when they come to a halt. You should try to make your driving as smooth as possible. This puts less strain on the car and makes tyres brakes etc last much longer.
53FabiaVRS is offline
Old 15-08-2007, 21:33   #6
UberMod™
Neo_VR's Avatar
NO NO NO!
under no circumstances use the TDI springs... the vRS has another 60kg over the nose than the tdi, and the springs sag too much.. you would suffer more diving and actually have problems scraping your undertray with these springs
ColGod the UberMod
VXR, Gti, ST, Type-R, vRS, Cupra, Shifty... An MPS fears not these things...
Neo_VR is offline
Old 15-08-2007, 21:40   #7
*tim*'s Avatar
Ok, no TDI springs. Even if they were suitable I wouldn't want to go any higher, it already looks like a 4x4 - hmm, theres an idea
*tim* is offline
Old 15-08-2007, 21:42   #8
*tim*'s Avatar
YAWN!
*tim* is offline
Old 15-08-2007, 21:56   #9
Don't talk, drive!
ncarring's Avatar
Hmmm, marketing rethink required
Nick
ncarring is offline
Old 15-08-2007, 22:01   #10
Briskodiodion
TeflonTom's Avatar
the springs i got from koni were listed as fitting the sdi, tdi, 2.0 and vrs
Old 15-08-2007, 22:06   #11
ScoobyChris's Avatar
While I agree with 53FabiaVRS's sentiments, the Fabia does have very pronounced diving and pitching even under the gentlest application of the brakes/accelerator. I opted for a set of Eibach springs and dampers, but I'm not sure if just the uprated dampers will solve it as it's the springs which increase the "stiffness".
Chris
ScoobyChris is offline
Old 15-08-2007, 22:25   #12
Don't talk, drive!
ncarring's Avatar
The dampers will just wear out quickly, if not matched with springs to suit.
Nick
ncarring is offline
Old 15-08-2007, 22:34   #13
*tim*'s Avatar
After reading more on the internet it seems that FSD's are designed to be used with standard strings up to 30mm drop, as the vrs is 25mm it should be okay. As too whether it would have the desired effect I don't know.
*tim* is offline
Old 15-08-2007, 22:39   #14
vindaloo's Avatar
Only thing I can think of is to fit either a "spring helper" of some sort. Fit a thickish dense rubber tubing over the lower rate part of the front springs would work. It'd force the higher rate part of the spring(s) to do more.
IMO it's mostly a spring thing, you can meddle with the progression of weight transfer with fancy dampers but you've got to get the springs somewhere near acceptable in the first place.
HTH
J.
Slowly turning the planet sooty.
vindaloo is offline
Old 15-08-2007, 22:45   #15
I parked up 1st
ric04vrs's Avatar
more/better compression damping on the shock absorber will stop the diving especially in conjunction with uprated springs
does anybody make shockers for the Fabia with adjustable compression ?
not so bored now
ric04vrs is offline
Old 15-08-2007, 22:46   #16
TBH, i like the ride on my vRS, however, with some "enthusiastic" driving, iv found it bottoms out too easy. I was thinking along the lines of dampers only, with standard springs. Dont want to make it too harsh as i do a lot of miles in it...
Disco_Mikey is offline
Old 15-08-2007, 23:18   #17
Nuts
anonymouse's Avatar
I think Wardy fitted Koni FSDs to his motor - do a search
"Stupidity, if left untreated, is self-correcting." - Heinlein
anonymouse is offline
Old 16-08-2007, 00:45   #18
200/370
Wardy's Avatar
Yes, indeed - Eibachs plus Koni FSDs here.
To be honest, I'd get them in conjunction with the Eibachs. Just take a little more care over speed bumps. Pretty much the perfect everyday setup, and I've tried every major combo on the Fabia platform, bar a coilover type setup! Near standard ride comfort and compliance, a touch harsher maybe, but hardly noticeable. Then when you want to press on, the dampers stiffen up.
You could just fit them with standard springs, yes, and they would make a positive difference. But I'm not sure you'd notice an improvement on the dive reduction front. You need a reduction in the spring coil for this to happen, or for the springs to be stiffer. You'd be missing out by not upgrading to Eibach springs at the same time.
Well worth the money in my book
Steve
Wardy's Fabia vRS
xenons : sunroof : cruise : OEM+
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is offline
Old 16-08-2007, 09:01   #19
*tim*'s Avatar
Thanks all for your replies, it seems that uprated dampers are recommended however with uprated (lowered) springs as well - this is gonna be expensive
Just too clarify a few points, I've never bottomed out on public roads nor by driving too fast, and I can't even remember the last time I drove over a speed hump The main problem is when I drive down muddy path / tracks and sump guard bumps on the raised middle section of the path. Generally only mud and stones so doubt it'll cause much damage....
Cheers all
*tim* is offline
Old 16-08-2007, 09:08   #20
200/370
Wardy's Avatar
It's a fairly expensive setup, there's no doubt. You could go to coilovers for less.
Just changing to Eibachs would help the most with nose dive, and for the least amount of outlay too. But you will notice a reduction in ride comfort and compliancy, and the OEM dampers will wear out quicker. Maybe look to replace springs now, and dampers later??
Steve
Wardy's Fabia vRS
Wardy is offline
