Welcome to the BRISKODA.net
, the world's largest Skoda owners and enthusiasts community. We focus on offering friendly advice, support and a dash of social activty.
We invite you to particpate too! By registering today you can participate in our active and growing community. Registration on the forum is free and simple, it enables you to post new messages, search and much more.
  • Membership of Skoda owners from over 75 countries.
  • Experienced advice from the community.
  • Local and national social events
Go Back   BRISKODA - The Skoda Forum and Community > Skoda Model Discussion Area > Fabia
Fabia Includes all models of Fabia, except the 2007 New Fabia.
LinkBack Thread Tools Display Modes
Strange handling
Old 20-05-2008, 08:18   #1
yegnold's Avatar
yegnold is offline
Car: CorridaRed VRS (130 BHP / 229lbs/ft)
Default Strange handling
Thanks to a stubborn 4x4 driver who was adamant that they weren't going to get their precious shiny car dirty, I was forced to go on the verge down a country lane about 3-4 weeks ago, and in the process managed to get the front left hand side of the car in a significant hole of some kind.
The handling on my VRS has been a little strange recently, and that is the only event that I can tie this down to... I can be going around a corner and suddenly the car will decide it is going to either turn in a little sharper or shallower than when I first entered the corner. The steering wheel just doesn't feel like it is directly connected to the wheels (at times) and sometimes can be quite heavy (this doesn't feel like a power steering issue)
Braking performance has gone down and the ABS seems to cut in more frequently.
A visual inspection of the suspension setup reveals no damage. We checked the tracking and it was ever so slightly out, but that has now been corrected.
My thoughts are that this has been caused by the console bush having been weakened by the "Impact" with the pot hole, and the strange handing around corners and strange behaviour whilst braking is caused because the wheel is moving slightly forwards and backwards when different turning forces are applied to it (due to a weakened console bush).
I might, however, be completely wrong (tyre wear at the moment seems to be even, but the tyres are relatively new (< 5000 miles)). Has anyone else got an idea of what may be causing this?
If it is this I was going to replace the console bushes with the Seat Cupra ones as I've been considering doing it for a while now.
Re: Strange handling
Old 20-05-2008, 08:27   #2
ASZ Eternal
ap0gee's Avatar
ap0gee is offline
Car: BlackMagic Fabia (165BHP / 280lbs/ft)
Default Re: Strange handling
AIUI, the bushes wearing has more to creaking over speedbumps, but I suppose they might have been permanently deformed by the impact. My money's on a buckled alloy, though...
Bring The Beat Back!
Old 20-05-2008, 20:29   #3
Lofty86's Avatar
Lofty86 is offline
Car: Yellow Fabia (135BHP)
A buckled alloy wouldnt make you steer shallow/oversteer i dont think.
Although if it is buckled, your abs would kick in alot more as your wheel is loosing traction when it gets to the flatspot on the wheel.
'53 Fabia vRS. PD160 intake, Green Cotton Filter, Pikey Intercooler Mod, 312mm Brakes. Debaged Rear End. Fixed The Rear Door Leak!
Old 20-05-2008, 22:05   #4
AndyG_1979's Avatar
AndyG_1979 is offline
Car: Black Fab vRS (130BHP)
Hmmm this sounds very similar to what I'm experiencing
My problem started back at Round 1 of the BTCC at Brands when I got stuck in the car park. I keep meaning to get it looked at but as I drive like an old women these days Ive just gotten used to it
Black Magic Fabia vRS
XBox Live: AndyG1979
Support Briskoda by joining FREEDOM!!!! click the image =====>
Old 20-05-2008, 22:07   #5
jasc1988's Avatar
jasc1988 is offline
Car: Magic vRS (Mapped Power)
Sounds like a wishbone....
Mines was doing this, pulling right under acceleration and left under braking, turned out to be a loose wishbone... maybe yours had been damaged by the impact
173.5 bhp
... Czech Mate
Old 20-05-2008, 22:24   #6
TommyC's Avatar
TommyC is offline
Could be a bit of both, buckled wheel along with bent or loose wishbone......
.......Bent or broken ARB drop link???
Fractured or bent console bush mount
Or any combination of the above??!!!!
Have you tried swapping the suspect wheel with the spare?? This may help with pinpointing the problem. It will give you the chance to inspect the wheel thoroughly but also see how the car drives with a wheel you know is fine......
And whilst the wheel arch is empty you can have a damn good look at everything in there (with a good torch!!)
WARNING : Jelly is not porous!!
What is the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons and civil engineers build targets.
Old 27-05-2008, 11:22   #7
yegnold's Avatar
yegnold is offline
I think we managed to identify the problem
A close visual inspection of the wishbones and the console bushes revealed that paint had flaked off the rear of the wishbones (indicating a significant flex of some kind) and that the passenger side console bush was slightly rotated compared to the opposite one.
The tracking was also out by a significant margin.
We're:
Replacing both wishbones (I decided I may as well do both sides at once)
Replacing the console bushes with the solid Cupra ones
Having a full wheel alignment check done after
Hopefully this will solve all of my woes!
Old 30-05-2008, 09:17   #8
yegnold's Avatar
yegnold is offline
We changed both console bushes to the SEAT ones and both wishbones last night, taking us about 4 hours in total (probably because we didn't use any lube to get the bushes in...)
The handling is now back to the way it should be (and, I think, a little better... though it's been so long since it handled properly I can't make a fair comparison)
Comparison of the old wishbones revealed that the passenger side one had indeed been bent slightly by an impact of some sort...
I'm getting the tracking done (at the moment the front wheels are toeing out quite a lot) and some new tyres put on the back this morning, so I'm hoping that by this evening the car feels like new again... I'll have a good opportunity to find out as I'm doing a 320 mile round trip to Pembrokeshire this weekend...
Old 31-05-2008, 14:53   #9
TommyC's Avatar
TommyC is offline
Glad to hear you've got it sussed and sorted out
Old 31-05-2008, 15:06   #10
Mossman's Avatar
Mossman is offline
Yep, good to hear all sorted out
Black Magic Fabia V/RS Xenons, Heated seats, Cruise, Cupra Front Splitter, new VRs badges, Koni FSDs, Eibachs, Jabba ARB, Jabba Remap, PD160 Intake and 312mm brakes + Detailed by Glyn O'Donnell
Black Magic Fabia V/RS Xenons, Heated seats, Cruise, Ecutek Remap, PD160 Intake (Yes I have two! )
Photography Marketing T shirts flickr
Old 31-05-2008, 16:04   #11
hardcore modder
Basil's Avatar
Basil is offline
Car: Black Fab vRS (2xx)
Those wishbone bushes are a right PITA - even if you use washing up liquid as a lube...
Bet you're glad you won't have to do that again!
btw - did you notice any reluctance to engage 3rd gear around corners? That has now gone away?
I found my console bolts to be loose and a good tightening sorted that prob out.....
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Old 01-06-2008, 09:19   #12
Cursed in Life
Chrispy's Avatar
Chrispy is offline
Car: Silver vRS (130BHP, for now...)
Even the dealers don't know why they fit such flimsy bushes as standard. They were asking me where I'd got my non voided ones from when it was in one time.
I simply said 'Seat Ibiza'.
One of the best things I ever did was fitting them. My creaking under braking and when going over speed bumps etc vanished and it made the front end seem sharper on turn in etc. Much better.
Silver '04 Fabia vRS. Custom Seat Surgeons Leather interior inc door cards, Whiteline RARB, Cupra Console Bushes, Aeros, Golf Sunglasses holder, Arosa Cupholders and soon to be 170bhp.....nice. Stil clunks though..
Old 02-06-2008, 11:26   #13
yegnold's Avatar
yegnold is offline
The handling is much better even just from the tracking having been put right. I had 4 people in the car for that 320 mile round trip and it was going around corners more comfortably than when I had just 1/2 people in whilst the suspension problem was still there.
One major improvement is the ease of gearchanges. I was beginning to struggle to change down gears smoothly as the wheels would move forwards/backwards when the gears were re-engaged after I'd released the clutch.. creating very slight fluctuations in deceleration and hence me getting very angry that I wasn't changing gear as smoothly as I always used to. This has now dramatically improved and all gearchanges are completely seamless again...
The road noise has barely increased and although I can feel a bit more feedback through the steering wheel, my hands aren't being shaken to death, even on rough roads...
All in all, very pleased!
vB code is On
vBulletin skin developed by: eXtremepixels
| Home | Register | FAQ | Members List | Calendar | Today's Posts | Search | New Posts |
Website © 2003-2007 BRISKODA.net
PLEASE NOTE - PERSONAL ABUSE, ABUSE AGAINST THIS OR ANY OTHER WEBSITE OR ANY COMPANY WILL NOT BE TOLERATED. OFFENDERS WILL BE MODERATED OR EVEN BANNED.
Ad Management by RedTyger
Search Engine Optimization by vBSEO 3.1.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
