strut top bolts torque
This is a discussion on strut top bolts torque within the Fabia I forums, part of the Skoda Model Discussion Area category; what should the strut top bolts be torqued too anyone know ???...
Old 06-01-2006, 10:36   #1
mcbunny's Avatar
Default strut top bolts torque
First step to recovery is admitting you have a problem
Hi, my name is Mike and I own a Skoda and to top it all off it’s a diesel.
mcbunny is offline
Old 06-01-2006, 10:55   #2
Mongreller
devonutopia's Avatar
Default Re: strut top bolts torque
I did mine to as tight as I could get them with a fairly small wrench (piddly one with 12" handle)
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 06-01-2006, 11:53   #3
Me too - that was over 10K ago and they're still on
Asked the Seat dealer what torque and he said 'Tight as you can'.
Bike with engine coming soon...
SteVRs is offline
Old 06-01-2006, 12:20   #4
mcbunny's Avatar
lol great i will blame you if the next owner kill them selfs
mcbunny is offline
Old 06-01-2006, 13:53   #5
AndyVRS's Avatar
Just tighten them down as hard as you can and check them in a couple of days should be fine. Prob won't need to check them but always do same sort of idea with wheel bolts
AndyVRS is offline
Old 06-01-2006, 14:09   #6
ScoobyChris's Avatar
Pretty sure it says 25Nm in the fitting instructions for the Seat strut brace - no idea if it's the same with/without the brace?
Chris
ScoobyChris is offline
Old 06-01-2006, 15:43   #7
That's a really good point - worth doing for anything you bolt that your life relys on.
SteVRs is offline
Old 06-01-2006, 16:04   #8
Proud Dad
Chavyboy's Avatar
Finger tight should do it
2004 '54' Citroen Picasso 1.6 16v Desire HDI in Wicked Red
2004 '54' Vauxhall Corsa 1.3 CDTI Energy
Ex Skoda owner
Chavyboy is offline
Old 06-01-2006, 17:07   #9
Skonda Fabic
Tight as you can !! No need for a torque setting
ChrisRs is offline
Old 06-01-2006, 17:41   #10
RallyRed's Avatar
i did mine as tight as i had found them they were alot easier to undo than id expected ie they werent on very tight
RallyRed is offline
Old 06-01-2006, 18:36   #11
Cheekymonkey's Avatar
Chris
I think it's 25 lb/ft... that's what I tighten to anyway. It's certainly not as hard as you can! Don't want to strip the threads out of the shock tower!
Dave
Ex - Fabia VRS Owner
Now Z4 Coupe
Cheekymonkey is offline
Old 06-01-2006, 22:31   #12
aixlad's Avatar
The instructions that come with the SEAT Sport Strut Brace states that the bolts should be torqued to 25Nm. This is certainly not as tight as you can get them! If you overtighten them and strip the threads, then you'll be extremely upset, and much much poorer.
(Hint: Buy a Torque Wrench, and have the satisfaction of knowing that the job has been done correctly )
I'm the only Skoda driver in the village!
4 Wheeler: Black Magic Fabia vRS, MSD Grill, SEAT Strut Brace, ESP, Side Airbags, Cruise Control, 3rd Rear Headrest.
2 Wheeler: Triumph Thunderbird Sport
aixlad is offline
Old 06-01-2006, 22:37   #13
U18 Automotive
Lummox's Avatar
Originally Posted by aixlad
This is certainly not as tight as you can get them! If you overtighten them and strip the threads, then you'll be extremely upset, and much much poorer.)
One of the most sensible and right things i've ever read on this site.
Its an M8 bolt for christ sake..lol
Unit 18 Automotive Services
Cupra Console Bushes
Servicing
Modifications
PM for information
Lummox is offline
Old 06-01-2006, 23:24   #14
aixlad's Avatar
Taking this topic even further, the technical community may appreciate this point of interest.
Bolts, such as those used for the top suspension strut fixing, are stamped with a Relative Strength Marking, and in the case of the Fabia bolt this marking is 10.9. At this strength, the maximum torque which this bolt can safely withstand, before risk of failure, is just 35Nm. So unless you can accurately judge 25Nm without enthusiastically going over, and beyond the 35Nm safe limit, you really should be using a torque wrench. Tightening it up as tight as you can would in my opinion be just as dangerous as not tightening it at all. I'm quite surprised at the number of posts in this thread where crude Agricultural Engineering practices have been used.
aixlad is offline
Old 06-01-2006, 23:35   #15
Mongreller
Which is why I'd never use my draper wrench on it. My mini-me wrench [sticks little finger in curled position to mouth] is incapable of tightening to more than 25nm I reckon.
Old 07-01-2006, 10:51   #16
I'm going to loosen mine off a tad then... used the wrong units, although still with a torque wrench. 25lb/ft = 33Nm so just inside the safe range - shouldn't have done any damage... I hope!
Dave
Now Z4 Coupe
Old 07-01-2006, 11:06   #17
U18 Automotive
Lummox's Avatar
I'd be suprised if it was 25lbft. All torques are given as nm (europe is metric after all) in workshop manuals ans fitting instructions for accesories.
Servicing
Modifications
PM for information
Lummox is offline
Old 08-01-2006, 00:26   #18
aixlad's Avatar
If you tightened them beyond the recommended 25Nm, then you may well have reached the yield point of the material, so you might be better off to leave them well alone for now, after all they are unlikely to drop out!
aixlad is offline
Old 08-01-2006, 10:07   #19
Mongreller
Did a couple of mine yesterday as I had to loosen off one end of my strut brace to access the filter box easier. I was wrong about m wrench - Its got about an 8" handle - also found I'd stripped out my 13mm socket (cheap cr4p I guess) - but conveniently found my 17/32" in the same set was unused and fitted well too.
Tightening up with that piddly wrench can't have made them any tighter than 25Nm.
