Suspension springs
This is a discussion on Suspension springs within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi- I had a front suspension springs go six months ago. The local garage I used charge £80 labour. I ...
Old 27-10-2006, 12:07   #1
Default Suspension springs
Hi-
I think another one went this week on the other side (same loud bang, found a piece on the road). Before I go back to the garage, I wanted an opinion as to whether £80 is a bit steep. They charged me £46.50 for the spring itself.
Any opinions would be gratefully received-
Thanks!
David
hallsy is offline
Old 27-10-2006, 12:11   #2
Default Re: Suspension springs
I had the springs changed on my Octavia, by a local garage, for £30 each.
I supplied the springs.
Goochie is offline
Old 27-10-2006, 12:34   #3
P.G
£80 labour for changing a spring !!
Short of whipping your trousers down and bending you over.........
I think you get the idea
literally a 30 min job max.
P.G is offline
Old 27-10-2006, 13:13   #4
ScoobyChris's Avatar
Assuming you have the VAG tool to open the bottom of the hub to locate the strut! Otherwise it can take considerably longer, imhe
Chris
ScoobyChris is offline
Old 27-10-2006, 17:19   #5
I parked up 1st
ric04vrs's Avatar
not only do you need the tool to open up the hub , you also require spring compressors to not only compress the strut to remove the spring but to compress the strut on the car to get it out of the hub
deffo more than a 30 minute job , more like an hour+ at least
not so bored now
ric04vrs is offline
Old 27-10-2006, 17:34   #6
bahnstormer vrs's Avatar
A local garage (NW London) charged me £150 + VAT to do all four springs when I had Eibach lowered springs fitted to my Fabia. Knowing the rears are a simpler job to do that the fronts I would have thought £100 + VAT would be the right price for the front springs to be changed (that is for the pair) i.e. £50 each.
A Skoda dealer might be a little more.
bahnstormer vrs is offline
Old 27-10-2006, 22:00   #7
RADIOTWO's Avatar
Originally Posted by hallsy View Post
Hi-
Thanks!
David
David
Why did you not replace both springs at the same time?
You should always change as a pair
Radiotwo
RADIOTWO is offline
Old 29-10-2006, 20:32   #8
Smile Re: Suspension springs
Hi
Just changed the springs on the front of my Fabia. If the spring has broken at the top where it sits on the bearing you will need to compress the spring on the car. I had no problem removing the strut from the hub without any special tool. The most difficult element was compressing the spring on the car. I also replaced both springs, both shockers (uprated gas), both bearings and replaced ruber covers on shockers. All parts came to less than £150.00. On removing the unbroken spring I noticed rust on the inner coil that sits on bearing.
The broken spring also damaged the bearing, these are only £7.50 so it seems silly not to replace when is all apart anyway.
Time for the whole job about 3.5 hours.
Andyt is offline
