vRS brakes worth anything?
This is a discussion on vRS brakes worth anything? within the Fabia I forums, part of the Skoda Model Discussion Area category; I've done the upgrade to the 312mm setup last week. Well worth it. Not given it any heavy duty braking ...
Old 09-07-2007, 16:06   #1
Default vRS brakes worth anything?
I've done the upgrade to the 312mm setup last week. Well worth it. Not given it any heavy duty braking yet, but my back has left the seat unexpectedly several time.
I have the vRS brakes all boxed up, wandered if there are worth anything?
To say less powerful modes??
My black beauties:
Fabia vRS MY05 - 180/285
Impreza STi MY04 - 392/361.
GazTheHat is offline
Old 09-07-2007, 16:12   #2
Default Re: vRS brakes worth anything?
You've NOT YET tested it and you have had your a55 off the seat... are your front shocks on their way out??
seriously if your thinking about trying to sell used parts here you may not want to advertise how the car may or may not have been driven - I'd assume it would put off potential buyers
You also need to add in milage covered by the discs & if you have a micrometer you could provide measurments. Otherwise the 2nd hand buyer may as well buy new & he'd then avoid the cost of P+P + peace of mind.
Welshy is offline
Old 09-07-2007, 16:27   #3
ScoobyChris's Avatar
Unfortunately all the other Fabias have FS-III brakes so not an easy swap (and if they were looking to change they may as well go for the 312's). Some of the Octy's have the same as the Fabia so the discs and pads may be saleable....?
Chris
ScoobyChris is offline
Old 09-07-2007, 16:42   #4
Want a go?
Decron's Avatar
As stated not really. Hold onto them and when you move on swap them back and you will get rid of the 312's a lot easier.
Decron is offline
Old 09-07-2007, 17:25   #5
PoloGaz's Avatar
as a slight deviation, is it possible to fit 280mm golf/corrado VR6 (for example) brakes to non VRS's without changing the hubs?
PoloGaz is offline
Old 10-07-2007, 14:37   #6
Are you drunk? Re-read my thread!
Thanks for the other comments. Guess i'll just keep them boxed and in the loft then. May try eBay, as anything goes there...
30k miles done, so doubt there's much life in them. Thought if they fit a less spec'd fabia, it might be a worthwhile cheap upgrade.
My black beauties:
Old 10-07-2007, 15:33   #7
Mmm Skodacious!
mac67's Avatar
What was the cost Gaz both for the parts and fitting as this is something i'm considering when i've got my wedding out of the way.
If this post can be interpreted in two different ways, it was meant the good way!
Fabia VRS 180 Angel Tuning re-map, Jabbasports rear ARB, PD160 air intake pipe and Green cotton air filter, Millers Diesel Power Sport 4 fuel additive, Briskoda sticker (front and rear windscreen), Navman F20, set of Rosary beads blessed by the pope!
mac67 is offline
Old 10-07-2007, 16:58   #8
mine are boxed away in the shed awaiting the day should I return the car back to standard. 28k on them and to be honest they look fairly new.
For the hassle of trying to sell them and the amount you get I really wouldn't bother.
polocoupe is offline
Old 10-07-2007, 17:45   #9
Smokey
Wardy's Avatar
The doubt in my mind would be about resale time, as there's a proven market for the 312mm setup. So you could make some money back then, by just refitting the std setup and selling the 312mm kit on.
You could always try them on eBay though - nothing ventured etc!
On the fitting of 280mm brakes to the lesser Fabia models, I think that may well be possible. You'd need new carriers though. This is all a bit vague I'm afraid, and based round my upgrade of Polo GTi 256mm front brakes, to 280mm from a G60. Worked very well and required the sourcing of the carriers (can be difficult to find for reasonable money) and obviously bigger discs and pads.
Steve
Wardy's Fabia vRS
xenons : sunroof : cruise : OEM+
"Racing is life. Anything before or after is just waiting." - Steve McQueen
Wardy is offline
Old 10-07-2007, 18:00   #10
PoloGaz's Avatar
I'm possibly wrong but the carrier might be part of the hub. Just had a look in haynes and there's no torque wrench setting for it in haynes for FS2/3 calipers) I didn't check when I did a disc & pad change a few weeks back. The new discs just fitted past the carrier so I didn't worry about it.
PoloGaz is offline
Old 10-07-2007, 18:09   #11
Smokey
Wardy's Avatar
You may well be right Gaz. Just thought there might be a slight chance that it had a similar setup to earlier Polos, like my 6N2.
Steve
Wardy's Fabia vRS
Wardy is offline
Old 11-07-2007, 13:36   #12
It was £295 delivered for the 312mm setup, from GolfTurbo(.com).
I had a 30k service done, new wipers and bulbs fitted at the same time as the brakes, so i don't know the fitting cost exactly. But that lot come to £240.
The initial brake pedal feel is the same as new OEM equipment, but press a little harder and the brakes are much much sharper. Haven't "really" pressed them yet.
Happy with the upgrade.
My black beauties:
Old 11-07-2007, 13:48   #13
So £535 for new wipers (say £40 for the lot) bulbs (unknown which ones youve changed I cannot imagine you had that many which had blown at a mere 30k....can you try a warranty claim on premeture failure of bulbs) & new dics.
Were your old discs no longer servicable? Was it a case of either replace the ones on the car for new std OEM's or upgrade OR was it a case of I want it now so I'll be environmentally unfriendly by scrapping discs which are not buyond their servicable life & who noonw would buy to use on their car with 30k on them unless its silly cheap £15 for the two.
I wonder if this is the same case as I ve read people with vRS's changing their exhausts when the ones on the car are not rotten/unservicable - the exhaust on my car is over 10 years old and still fine and the one on the Golf GT TDI115 was fine at 7 years old and 60k.
It appears that many of the modifications are done before the original parts have worn out and therefore its an anti green attitude that modifiers have.
I wonder if the Govt will pass legislation like that in France where you cannot modify the engine only the brakes.
ALso I had the great pleasure this week of recording someone talking about a specific garage where an MOT was carried out this person simply called them and they said fine we'll pop it in the post (no actual test carried out & cert provided). DVLA informed & Trading stds informed - hopefully the garage will lose its MOT licence. It all came about when I asked how did it pass the emissions test as it had its cat removed then he spilt the beans & luckily my PC microphone recorded it all.
Welshy is offline
Old 11-07-2007, 14:05   #14
A few years ago there was an MOT station round this way who "specialised" in testing cars that were decatted. The way they did it was to MOT the car and then use a donor car for the emissions test which happened to be an old Nissan Micra. Unfortunately, the year my friend took them up on this service, the Micra actually failed on the emissions test so he was no better off and had to get his car recatted for the day
Chris
Old 11-07-2007, 14:10   #15
This practice of dodgy MOT certs is a real concern - the emissions test is crucial especially considering the global warming issue.
If they break the law on that what else are they missing? Are they failing parts which are fine to get more £ out of you?
The law is there for all to abide by and if any of you champion this sort of illegal behaviour rather than a childish response please state why you or someone else's car you may have heard of that passed in a dodgy way should not have to pass the same test as everyone else who abides by the law. If its convincing send it to the DVLA so that they can give their view of your thoughts.
Welshy is offline
Old 11-07-2007, 14:18   #16
Smokey
Wardy's Avatar
You really are something else.
Wardy's Fabia vRS
Wardy is offline
Old 11-07-2007, 14:27   #17
Im sure you want all MOT test centres to be acting in a legal and ethical way & all garages not ripping you off as rule breaking goes hand in hand with carrying out unnecessary work.
You have been warned.
Welshy is offline
Old 11-07-2007, 14:43   #18
Smokey
Wardy's Avatar
I've been warned have I? OK, well thanks for that. You're a life saver. Do you work for VOSA or something?
Or just spend your entire time worrying about issues that it's possible to worry about? Today it's MoT test centres and people being apparently environmentally unfriendly. Will tomorrow bring you worrying again about people not buying BMWs?
Wardy's Fabia vRS
Wardy is offline
Old 11-07-2007, 14:51   #19
You can clearly see the issue of dodgy MOT centres if they are willing to do illegal emission tests what else are they willing to bend the rules on?
Note - you clearly are a sensible chap and therefore know that the whole point of a cat is to prevent harmfull chemicals entering the atmosphere - if you remove it (illegal to do so) you are increasing the emissions for your car.
I put the warning there as too many get away with it imagine there is a crash as a "friendly" MOT centre didnt carry out the brake test and that killed someone. Its not the drivers fault its the MOT centre.
Welshy is offline
Old 11-07-2007, 15:10   #20
The emissions test is slightly different however. Most owners will re-cat their car to get it through the MOT and then decat it again the day after. So, rather than going through the hassle of paying someone to switch over the exhaust twice for an hour's test, they doctor the emissions.
I'm not saying I agree with the practice, but I'd hardly say it's in the same league as not carrying out a brake check, etc.......
Chris
