This is a discussion on Which vRS engine ? within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi guys, Sorry if this is a dumb question, I've tried searching on here already but can't find a straight ...
| Briskodian Join Date: Apr 2008 Location: Leeds
| Hi guys, Sorry if this is a dumb question, I've tried searching on here already but can't find a straight answer. I understand there are two different engines that were used in the Fabia vRS, was wondering how to tell which I've got in mine (it's an 05 plate, if that helps), is it also true that the bhp figure of 130 was underestimated by Skoda ?, if so whats the true figure likely to actually be. Cheers Alan |
| Briskodian Join Date: Oct 2007 Location: Dumfries & Galloway
| You will have the ASZ engine, No engine stutter ![]() On the newer BLT engines they seem to have more power, a few have rr at 145-150 bhp. But taking into account no rr is accurate i'd say it safe to say most older ASZ's will be not far off the 130 ps as stated by Skoda ![]()
__________________ |
| Briskodian Join Date: Jul 2006 Location: Newport/Preston
| You'll have the one that isn't the BLT ![]() |
| Thanks for that guys :-), glad it's not the one with the st-st-st-st-stutter. Alan |
| | #5 | |
| Quote:
Wh-Wh-Wh-what? I get it now ![]()
__________________ | |
| Briskodian Join Date: Mar 2008
| sorry to knick ur post here but which is the best to go for then age wise?? |
| The stutter isn't too bad tbh but if you dont want it look for an ASZ engine coded fabia, the early 53/04's had the older longer 6th gear. Some 04's like mine got the never revised shorter 6th gear. Think the ASZ ran to 55 plate / 06 but im unsure.. im sure a search would reveal all however
| | #9 | |
| resident gayer Join Date: Mar 2007
| Quote:
__________________ 2nd most powerful car on awesome rolling road day ![]() | |
| | #10 |
| mmmm very interesting.cheers thats something to look into when i'm searching for one!! cheera |
| | #11 |
| Briskodian Join Date: Mar 2008 Location: Stirling
| Sorry to hijack again,,,, my vrs is a 55 jan 2006,,, which engine do you think it is and is that good or bad ?? |
| | #12 | |
| Quote:
Look at your V5 log book, tells you on there (engine number) Will start with either ASZ or BLT, ASZ being the old and BLT the newer
| | #13 |
| Engine: BLT from october 2005 ASZ from june 2003 until ^^ Gearbox: FJW (may-june 2003), FSM (from july 2003) - the older ones with longer 4th,5th and 6th HDS from january 2004 |
