This is a discussion on vRS oil level within the Fabia I forums, part of the Skoda Model Discussion Area category; When is the best time to check the oil level on my fabia vRS, when the engine is warm after ...
| When is the best time to check the oil level on my fabia vRS, when the engine is warm after running or before i start it in the morning when the engine is cold? Cheers |
| Briskodian Join Date: Feb 2006 Location: West Midlands
| What does the owners manual advise? You're better off changing the oil when the engine (and oil) is warm, as it's viscosity will be lower. As for checking it I am not sure whether it matters, but if you do check it when the motor is warm, ensure that it's been stood (switched off) for a short while in order to ensure all the oil has drained back into the sump ![]()
__________________ Xbox 360 gamertag: TexasJohn74. Last edited by texasjohn; 14-04-2006 at 17:30. |
| Briskodian Join Date: Nov 2003 Location: Cornwall
| The oil should not expand under heat, only change in viscosity. The level can be checked when cold, or After the engine has been run, turn it off for 10mins for the oil to drain back into the sump before checking.
__________________ Andy Laws Fabia vRS |
| I take it that the 'MAX' mark is at the top of the hatch markings? |
| | #5 | |
| Briskodian Join Date: Aug 2004 Location: /usr/bin/whereis `whoami`
| Quote:
__________________ I'm the only Skoda driver in the village! 4 Wheeler: Black Magic Fabia vRS, MSD Grill, SEAT Strut Brace, ESP, Side Airbags, Cruise Control, 3rd Rear Headrest. 2 Wheeler: Triumph Thunderbird Sport | |
| | #6 | |
| Briskodian Join Date: Jun 2005 Location: Midlands UK
| Quote:
| 3cms? that way up the dipstick. Top of the hatch is the maximum.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| Briskodian Join Date: Oct 2004 Location: Gloucester
| Top of hatch is definitely NOT the max level - from the manual: "Oil level within range (B) [the hatched zone] - you may top up the oil. It is possible that the oil level may then be within range (C) [the bit above the hatched zone] after doing this." i.e. the top of zone C - the crank - is the MAX level. Addendum - incidently after the 10,000 mile service the oil level was about 3mm above the crank and after the 20,000 mile service it was at the crank itself.
__________________ David - Skoda Fabia vRS - October 2004 facelift Last edited by DRJ; 15-04-2006 at 14:41. |
| | #9 | |
| Quote:
__________________ David - Skoda Fabia vRS - October 2004 facelift | |
| | #10 | |
| Quote:
Addendum - of course the engine will also expand so the potential oil level variation will be minimised as a consequence...
__________________ David - Skoda Fabia vRS - October 2004 facelift Last edited by DRJ; 15-04-2006 at 14:39. | |
| | #11 | |
| Briskodian Join Date: Mar 2006 Location: Anglesey
| Quote:
| | #12 |
| Ah well ![]()
__________________ Xbox 360 gamertag: TexasJohn74. |
| | #13 | |
| Briskodian Join Date: May 2005 Location: North East UK, Gateshead
| Quote:
__________________ ![]() Vorsprung DERV Technik | |
| | #14 | |
| Briskodian Join Date: Jan 2006 Location: Knutsford
| Quote:
| | #15 | |
| Quote:
| | #16 | |
| Quote:
I'm right in the general context - even water expands when it's heated from room temperature. Yes, water expands when it turns to ice, but critically it also expands when it goes below 4 degC. "Water has a unique property. As the temperature decreases to 40°F (4°C) the molecules slow, water contracts and the density increases. Below 40°F (4°C) the molecules begin to bond to each other and as they do, the water begins to expand again, decreasing the density. At 32°F (0°C) all molecule are locked into a crystalline structure with a resulting nine percent expansion in size. This expansion, and corresponding decrease in density, is the reason ice floats."
| | #17 | |
| Quote:
| | #18 | |
| Quote:
You beat me to it!
| | #19 | |
| Quote:
| | #20 | |
| Briskodian Join Date: Jan 2004 Location: Lincs
| Quote:
