This is a discussion on Wear rate on Eagle F1's compared to Proxes T1-R's within the Fabia I forums, part of the Skoda Model Discussion Area category; Tried a search and haven't found anything about the wear rate on these two tyres compared to each other. I'm ...
| Briskodian Join Date: Jun 2005 Location: South UK
| Tried a search and haven't found anything about the wear rate on these two tyres compared to each other. I'm either going to get one of these two or the Kumho Ecsta Supra 712's. Just want to know whether theres a lot of difference between the wear rate though. I suppose the Toyo's being assymetric it would be better if I ever had a puncture? |
| Briskodian Join Date: Apr 2005 Location: Yorkshire
| Take a look at this site it reviews loads of tyres: http://www.tyretest.com/pkw_sommerreifen/index.html I had a look though and i rekon the best value is the Perelli P Zero Nero, found it on mytyres.com for £63 a corner and really well rated tyre. Also take a look at the Bridgestone Turanza ER 300 £80 a corner and the Mitchlin pilot Exalto PE2 but there bit steep at £90 a corner. I its the eagle F1 go for the GS-D3 again bot £80 a corner Hope this helps and happy sopping Carl |
| Skonda Fabic Join Date: Jun 2005
| I rate Khumo's very highly |
| rider of sharks Join Date: Apr 2005 Location: Cumbria
| I have F'1s and rate them, my tyre guy puts them on the police suburus, and tells me not to use the toyo's 'cause they wear too quick ![]()
__________________ Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red.... ![]() Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!) |
| Fabian Join Date: Jun 2004
| By all accounts the Toyo T1-R wears less quickly than the T1-S did. Mine have been on for 13,000 miles and still have about 5 mm on the fronts after one front-to-back swap. I'll be replacing them with more T1-Rs when the time comes. |
| | #6 | |
| Quote:
I've heard that the new ones are better than the old...... anyone had a set on the front without rotating and know how long they lasted? I got 17,000 miles out of the conti's......
__________________ Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red.... ![]() Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!) | |
| It's all good Join Date: Oct 2005 Location: Cwmbran - South Wales
| My VRS came fitted new with Bridgestone Turanza ER 300's and after 6000 miles (3000 of those done with the OneClick ) they are barely worn at all. With rotation they should hopefully go to 20k. |
| | #8 | |
| Quote:
| | #9 | |
| Briskodian Join Date: Jun 2004 Location: Okehampton
| Quote:
Edit : Thats on an Octy. Last edited by MisterGT; 09-01-2006 at 08:28. | |
