This is a discussion on what VRS bit do i need to put 312mm brakes on my car? within the Fabia I forums, part of the Skoda Model Discussion Area category; Its a 1.4 16v. i'm thinking i need Fabia VRS hubs and hub carriers anything else? Also are the VRS ...
| Briskodian Join Date: Dec 2005 Location: scotland
| Its a 1.4 16v. i'm thinking i need Fabia VRS hubs and hub carriers anything else? Also are the VRS rear brakes any bigger than the one on teh 1.4?
__________________ My Audiworl sig i too lazy to do a briskoda one |
| Briskodian Join Date: Nov 2005 Location: Dubai
| I think that the rear ones are the same.. as for the 312mm brakes.. hmmm i really dont think its very necessary on a 1.4.. if u have bigger wheels that would be enough.. I have the standard brakes on my 1.4 but with 17" wheels.. the braking is truely awesome and everyone who rides with me gets shocked when i slow down from 140 to 40 or 20 in a very short distance...
__________________ 1.4 16V |
| Want a go? Join Date: Oct 2005 Location: Cwmbran - South Wales
| The VRS is a lot heavier and when remapped will go a lot quicker hence the popularity of the 312mm upgrade. You may be better off with a nice set of regular sized slotted and dotted discs and some uprated pads such as greenstuffs or the Ferrodos, I would consider that a much more cost effective upgrade for yourself. |
| Mongreller Join Date: Apr 2003 Location: Ooo-ar, Oi be from Devonshire
| You need the complete outer hub housing for the front (no rear mod possible) and its advisable to putnew bearings in them, rather than remove/refit your old bearings. That's it. As the 312mm kit comes with the carriers to bolt on totje hub. For non-vRS Fabias, it just adds another £400 odd to the price (assuming brand new outer hub housings and inner bearings)
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. See the mongrel's 260bhp Dyno Video! |
| Which i stll think is not really necessary for a 1.4 .. for that money you can go for a better mod
| | #6 | |
| Quote:
I have a bearing thats just startng rumbling aswell so its an ideal opertunity. I priced black diamond dics and pads for the 1.4 fabia and nearly died 195 quid for discs and 50 quid for pads.. and what magic makes your 1.4 do 140? I eventually plan to put a different engine in mine and then itll do 140 and beyond
__________________ My Audiworl sig i too lazy to do a briskoda one Last edited by RallyRed; 14-04-2006 at 10:54. | |
| | #7 | |
| Quote:
| | #8 | |
| Quote:
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| This is the toolage for wheel bearings btw.. ![]()
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. Last edited by Lummox; 18-04-2006 at 09:21. |
| | #10 |
| Any links to a source and cost for that "toolage", Ross? ![]()
| | #11 |
| Source? Skoda I guess. Kit is about £300 iirc.
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| | #12 |
| Would a hydraulic bench press do or does it really need the specific tool?
__________________ |
| | #13 |
| You really need the propper tool as it supports the bearing correctly and makes sure the outer ring (the silver bit that isnt pushed in) sits properly in the hub.
| | #14 | |
| Quote:
__________________ 1.4 16V | |
