This is a discussion on Whats the alternative to... within the Fabia I forums, part of the Skoda Model Discussion Area category; Revo? I know Revo stays on the ECU, and there is a company that do ECU Flashes that doesnt if ...
| is hating life! Join Date: Aug 2007 Location: Dont Know, Dont Care
| Revo? I know Revo stays on the ECU, and there is a company that do ECU Flashes that doesnt if taken off? Or am i thinking crap?!
__________________ Id rather be a nobody than an overated someone... |
| Briskodian Join Date: Jun 2004 Location: London/Aberdeen
| I thought all maps left some kind of code deep within the ECU.
__________________ Heather |
| I thought i read somwhere that REVO leaves a trace and this A.N Other doesnt...
| GIAC resets the counter each time it is loaded and unloaded via the flash loader unit.
__________________ |
| Briskodian Join Date: May 2007 Location: Shropshire
| Are you thinking of the Revo free trial period map? You can get a try before you buy map which reverts back to standard after a certain length of time. Except it doesn't! It locks the ECU or puts the standard map back in a different way (i think!). There have been some people on here who have been unable to get their car remapped by a different tuner if they have used this free trial Revo map without getting Revo to unlock it first. Someone please correct me I have got this wrong! ![]() Mark |
| | #6 | |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn coutry
| Quote:
HTH | |
| The Following User Says Thank You to fatty5000 For This Useful Post: | KLM (21-02-2008)
| Briskodian Join Date: Oct 2006 Location: Still in Suffolk
| Can't get a Revo trial on a PD engine. So no need to worry ![]() But, yes it would revert back to Revo's 'standard' map not the map you had before hand. Youngsyd, I'm not even sure what your question is But as said most tuner will keep a copy of copy of your current map on file so it could be flashed back at a later date. HTH |
| The general question was does a REVO remap leave a trace on the ECU once taken off?
| | #10 | |
| Quote:
I may be wrong though ![]() | |
| | #11 |
| Does it not change the flash counter? |
| | #12 |
| Good point, it probably does unless it's done on bench and the chip is completly wiped and a fresh copy of the standard map is put on. Which in theory wipes all data stored on the chip including the flash counter (this is assuming the flash counter is held on the same chip and not in the convience module or somewhere else). Again I could be wrong. |
| | #13 |
| Hopefully someone can confirm ![]() ![]() |
| | #14 |
| Briskodian Join Date: Apr 2007 Location: Horsham
| All I can confirm is that it's the best 300 ish quid I've ever spent! People say how fun it is to drive a vRS but not as fun as having a remapped vRS! |
| | #15 |
| Briskodian Join Date: Oct 2007 Location: Dumfries & Galloway
| It will leave a trace as the standard Revo map is there map not the Skoda original map
| | #16 |
| Thanks for that.
