Coming soon, the greatest Favorit project ever! (Probably)
Coming this Autumn (As of 10 Sept 09...well, when I finally get some more money to buy more kit!!) to a project journal near you....
The Electric Favorit! Henceforce to be known as "Project Favelec"!
Some taster pictures below :eek: :thumbup:
Edited by favguy
  • Replies 326
  • Views 89.2k
  • Finally it's legal!! Had a trip to the DVLA at Beverley today, no hassle at all and the car is now registered as an Electric. And the best part is the "NIL" duty rate, so I splashed out and went with
  • An inaugural voyage, and the longest MOT... I've been grinning like a demented cheshire cat all day today. I'd been scurrying around all weekend finishing off bits and pieces ready for the MOT test
  • Saw this at the show today and talked to the owner.   Without a doubt this is THE best Skoda based project I've ever seen. I was simply in awe of it and just kept standing there looking at it.
Yes it's the FavElec!
Unleaded sir?
No thankyou, I prefer 230 volts !!!:eek:
Latest thoughts on specs...@ 08/03/2010:
Base Vehicle: 1995 Favorit GLXIe Flairline, 20,000 miles from new, restored to as new condition.
Electrical System:
147.2 Volt Direct Current system, power source, probably 46 x 3.2v nominal, 160Ah Thundersky LifeYpo4 lithium cells in series pack configuration.
Voltage and current control via
Curtis controller 1231C-8601 (or a self built open source 500A controller..), supplying an FB1-4001A Advanced DC Series Wound Motor rated at 30HP (or possibly a warfield Warp 9 motor)
Transmission will remain standard but become semi automatic, or "clutchless" in the new drive system
Approximate calculated performance specs:
0 to 60mph in 14 seconds
Top safe speed of approx. 80mph
Constant crusing speed capability of 70mph
Maximum range of 120 miles, realistic range of 100 miles
Full recharge time from any 230v wall socket from full discharge, approx. 8 hours.
Local emmissions: ZERO!
Emmissions at power station source to provide charge current, approx 25% of equivalent petrol driven Co2 emmissions assuming most dirty production, ie. coal. Nuclear would be virtually ZERO!
Any questions, feel free to ask me :D
Edited by favguy
Updating spec.
cool!
Not a lot of people know this, but Skoda actually built and sold an electric Favorit, the Favorit Electra in the early nineties...:)
I dare you to lick the batteries....:P
On a more serious note, how much is it going to cost, and where has the electric system come from??
Total estimated cost is £6,000, all the main kit is coming in from California:) Batteries are also from US, but can be sourced here from golf cart supply specialists.
You can lick the 144v supply if you'd like, would you also like a wet sponge on your head so you don't suffer too much? LOL :rofl:
PS, and before anyone comments, as this much kit is going on a lovely Favvy with a market value of all of about £300, it will be insured with a specialist kit car insurer with an agreed value to cover the full build cost:)
Chicken:P:rofl:
Looks like it will be a good project though. Are you doing all the work yourself??
This is so cool... always thought about doing something like this to a car!!
Keep us updated please.... very interested to see how things comes along!
Phil
Yes, I'm planning to do all the work myself, fortunately I studied Electrical Engineering so am ok with it all, although to be honest, it's not that difficult and there are loads of US forums to get up to speed on the topic :)
I'll do you all a full photo build log as I progress.
Cant wait to see it mate!
The bonnet ok?
Have you worked out how much it would cost to charge up?
Hi Steve,
Yes the bonnets the right colour, and I've polished it so both sides are shiny now! ;) I've got to seam seal and paint the inside outer edges yet to match, and it won't get fitted until the engines taken out and the motor and all the electric kit has been installed in the engine compartment.
When it's finished I'll bring it to the local Skoda meet!
I can't tell you what charging cost will be yet, until I've checked what I'm paying per Kwh for my electricity or tried the charger on the battery pack (which I don't have yet!) but I expect it to cost around £2 per charge, which should give a range of between 60-80 miles depending on final weight, efficiency & driving style.
*UPDATE* 14/07/2008, It will only cost around 55p per charge when I get on the right nighttime tariff :thumbup:
Regards
Paul
Edited by favguy
cool project. but with some of my journies, unless it were capable of 400+ miles on one charge, or there were really really regular places you can charge up at on the way, it would not be feasible for me.
Have you worked out how long it will take to recoup the £6000? ;) For me in my mental maths, I would imagine in fuel terms alone, it's 300 miles for £10 (say) compared to 300 miles costing £35 in unleaded. £25 per 300 miles recouped, £6k back in 72,000 miles. Then there's the £200 (is it usually?) road fund license per annum. What wear and tear like on electric motors? I imagine reliability is good over combustion engines in general? :thumbup:
Smart A$$ ;).
I like the idea of this - to be honest I would have to see how reliable it was before doing all that to my car.
Smart A$$ ;).
I did do the 72,000 miles bit on a calculator though. :D
Will like to see this when its finished.
Good luck with the build.
Devonutopia,
Regarding the range, you are of course correct, if I need to do long journeys I'll use my other car (which is Petrol/LPG powered!) My normal daily car use almost never exceeds around 50 miles max so it'll be fine 90% of the time.
In any case, when the original Lead Acid battery pack dies after around 4 to 5 years of use, I intend to upgrade to Lithium Iron technology, this will give a range of around 120 miles due to much higher capacity and approx. 300kg weight saving!, these packs are prohibitively expensive now, but like any new tech. in 5 years should be affordable, they also have an expected life of 100,000 miles plus.
As to cost efficiency of the project, well in reality it's just not cost effective, especially compared to running on LPG as I do now, the break even point is probably a decade away, this will lessen when petrol gets to around £3 a litre in about 3 to 4 years, but it's still not going to save me money any time soon...
Motors last at least 1,000,000 miles (no kidding!) with brush changes every 80,000 or so, takes 15 minutes and doesn't cost much! The costly bit is the battery pack. but remember, you never need to change oil, oil filter, air filter, plugs, leads, cam belt/chain, exhaust, clutch etc..
The reason for the project is just to do it, for the pleasure and the hell of it and to prove I can, I like engineering challenges and taking one thing and re-engineering it into something else, I suppose I'm just very eccentric, after all I think favorit's are great :rofl:
Robshaw,
Reliability depends on how well engineered the conversion is, there is no universal kit for this kind of thing!, beyond choosing well matched and reliable drive system and safety components, which is quite easy due to the experience of 100's of americans who've been doing this for the last 20 years and online forums, it's all prototype work, really shouldn't be taken on by anyone who doesn't have the necessary experience in electrical and mechanical engineering along with good metalworking skills, (especially the electrical side, 144v high current DC can be very dangerous (electric chairs use high current DC!) or shorting out the batteries can cause a big explosion!)
Most importantly, you need a huge amount of patience! Only time will tell if my effort is reliable...:)
For anyone who's interested, look up DIY Electric Car Forums - Electric Vehicle Build and Conversion Community
Edited by favguy
I was way out on the charge cost by the way, if I switch to an economy night time tariff, it's about 55p per charge :thumbup:
how heavy are the batteries?
Looks mighty interesting project.
I can testify to the power of traction battery packs when shorted (by accident) I completely fried the tendons in a finger over 40 years ago.
I assume this controller is a dc chopper type device driving the motor in a pulse width / speed manner. The ones i worked on used SCR's that occasionally 'fired through' with either hilarious results or more often disasterous collisions with buildings and people!
Good luck with it all
Is there any chance that you would be able to use one of those solar trickle chargers?
You could just leave it in the back window... that way when you're parked up it will be sticking a bit of charge back into the batteries.
Phil
Hi all,
Yes the batteries are very heavy! Total battery weight will be between around 522Kg's (update 23/05/11 actually 257Kg's) eek: Suspension springs will be updated to accomodate the extra weight. Although, I do lose around 200Kg's from the petrol component removal.
Yes, I think the controller works by chopping the voltage, switching on and off at very high frequency, if it fails, (which is unlikely with the chosen unit, very good reputation against failure) it does fail full on! hence two contactors are used to cut power by the ignition switch in the event of failure (for safety in the event of one arcing closed) a further manual release for the master breaker is installed and then an inertia switch to cut the power in the event of an impact!, so hopefully I've got safety covered.
Re the solar trickle charger, these are 12v and the best give out about 5 watts!, I might use one to top off the 12v auxillery system battery, but even for this it would have to be out in the light for days to have much of an effect.
Regards
Paul
Edited by favguy
Im very impressed with this paul, i really cant wait to see it!
Got an ETA for completion?
Hi Steve,
I'd really like to have it done before the end of the year, depends on finding time and some money for it as I'm currently committing far too much of both to my business! This should ease by the end of August I hope when I can get stuck in properly:thumbup:
  • 4 months later...
Can't wait to see some more progress on this project, looks great :thumbup:
