BRISKODA.net: A word of advice/warning - BRISKODA.net
Page 1 of 1
A word of advice/warning Rate Topic: -----
#1 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
  • Car:MY11 Audi S3 Sportback S-Tronic
Posted 21 September 2008 - 07:36
Saw a worrying issue yesterday which occured on a brand new Octavia II.
It seems that VAG have switched to a new MK60 ABS controller, MK60EC/1 (ABS/ASR/ESP) and MK70M (ABS/ASR) which now uses long coding. Whilst coding another device on the car the ABS controller cleared itself of any coding at all. Normally this might not be too much of a problem as with VAG-COM/VCDS you can actually 'build' the new long coding with the information in the label file, however sadly this new controller isn't yet supported by VAG-COM/VCDS.
As it happened this car was in a Skoda dealer which had the latest revision of VAS software - The controller isn't yet supported by that either!!! How fecking rediculous that VAG are building cars with components that the dealers cannot support.
A quick call to our resident expert also confirmed that it happens on VW cars at the moment too.
In the short term the common sense way to overcome the problem is to carry out a full autoscan with with VAG-COM/VCDS and save it, this will show the current coding of all the controllers in the car which can then be re entered if the coding is lost.
The result in this case is that the car is now off the road until tomorrow when Skoda Technical can be consulted.
This post has been edited by VRStu: 24 September 2008 - 20:39
Reason for edit: More Info Added
#2 User is offline   sms
  • 2.0 FSI Sport.
  • PipPipPipPipPipPipPip
  • Group: Members
  • Car:Mk2 Octy Sport
Posted 21 September 2008 - 13:19
i guess skoda technical wont be told about it being vag com'd then? cheers for the info stu!!
#3 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 21 September 2008 - 14:42
It wasn't VAG-COM that caused the problem it was VAS. Regardless of that, VAG-COM is a proper tool and therefore shouldn't have any effect on warranty unless it caused a problem.
I should add that I am of the opinion that the problem is only caused when changing anything that communicates with the ABS controller.
#4 User is offline   phiL&K
  • Briskodian
  • PipPip
  • Group: Members
  • Car:L&K octy2 estate 140.
Posted 22 September 2008 - 20:44
Thanks for the advice VRStu:thumbup:
#5 User is offline   Theresias
  • Briskodian
  • PipPipPipPip
Posted 26 September 2008 - 10:20
To add some more info on this subject, the new modules are also installed in the new Audi A3 as well as some VWs - problem so far is that none of them comes with a coding table and the general rule is to request the original coding from the factory.
We have seen a similar behavior of ABS modules which lost their coding in the past, back then it was a safety measure which could be triggered by several things. A power supply problem as well as an unlearned steering angle sensor could cause this, so we believe this is a safety measure as well.
The next VCDS data update will have a label file for this control module but reality is that its unlikely we see coding details until then, so for now I suggest to follow Stu's advice - make a backup before you make any changes.
#6 User is offline   greg123
  • TDi Guru
  • PipPipPipPip
  • Group: FREEDOM
  • Car:too many to list, Inc '02 Octavia L&K Estate 1.8T auto - FOR SALE
Posted 26 September 2008 - 23:10
Nice one Stu. Hopefully by the time I get my hands on them it will all be resolved... (circa 2 years or more).
#7 User is offline   Tech1e
  • MPi Guru/Skoda Mtech
  • Group: Honorary
  • Car:Fabia 1.4 MPI+
Posted 29 September 2008 - 18:46
Its happening more and more with the VAG control units. It can be a pain even for us in the dealer network as it relies on
1) the VAG server being upright and able to communicate with the VAS machine
2) the company server being upright and able to communicate with the VAS machine
if 1 or 2 fail
3) It has to be a weekday and someone has to read the cry for help on DISS at HQ to email the factory, get you the long coding, then update the DISS report with the information, which to be fair to VW anyhow the technical team are very good at (if they are there...lol).
#8 User is offline   roo
  • COYW
  • Group: Honorary
  • Car:White thing with 4 wheels. Looks like it could be a police car
Posted 30 September 2008 - 05:09
Would it not be possible for the dealer to scan one of the cars they have in their showroom to get the coding?
As surely it would have the same controller and coding, or would they not risk the chance of losing the code for that one too?
#9 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 30 September 2008 - 05:40
The 'doner' car would have to be of exactly the same specification as the one the code was required for so yes if you have one available that should work.
#10 User is offline   VAG-tech
  • Briskodian
  • Pip
  • Group: Members
  • Car:Audi TT
Posted 19 April 2009 - 08:56
Forget VAS and Vag-Com, have you guys not heard of Autologic from Diagnos?
This post has been edited by VAG-tech: 19 April 2009 - 11:17
#11 User is offline   Theresias
  • Briskodian
  • PipPipPipPip
Posted 19 April 2009 - 09:16
For reference... Since everybody should make up his own mind. :)
VAG Diagnostics
#12 User is offline   greg123
  • TDi Guru
  • PipPipPipPip
  • Group: FREEDOM
Posted 19 April 2009 - 23:18
Yes but why would we want something more expensive with less support, forums and users that is more basic?
#13 User is offline   sparky2
  • Briskodian
  • PipPipPipPip
  • Group: Members
  • Car:Octavia FL Scout TDi (me),Fabia TDi (wife),Fabia VRS SE (son)
Posted 25 September 2009 - 14:23
:confused: Looks fancy how much is it though ?:rolleyes:
Share this topic:
Page 1 of 1
Fast Reply
Loading
