Skoda Retro/Replacement Badges
Bear with me on this one, as this is my first attempt at sorting something like this out but in theory it should be easy.
Having seen the intial "idea" thread I instantly knew the perfect supplier that I deal with day to day via my employment.
Logos were supplied and a sample produced:
Plastic material with brushed stainless steel finish
printed with black
then covered in domed clear resin
With this being met with favourable reviews a group buy is on the cards (and should quantity be large enough the price may even come down)
I have currently had 2 sizes priced
  • 55mm diameter for alloy wheels centres (and possibly steering wheel centre - someone with more knowledge will have to confirm)
    • £6 each
    [*]80mm diameter for bonnet and boot
    • £8 each
Simple enough so far! :thumbup:
However i opened my big mouth :rolleyes: and suggested that colour coded versions may also be available. A quick chat confirmed it would be possible however it might increase the price slightly but I am still waiting for confirmation from my supplier.
so essentially current options are:
standard - stainless steel with black
or
custom - colour of your choice (sensible please :P)
in sizes 55mm or 80mm
please list by reply (a copy and pasted full list please) how many of each size you are after and if you would want standard or custom (if custom list colour suggestion too) - ie:
PastyBoy - standard 80mm x 2 - custom 55mm x 4 (red with black)
Look forward to hearing from you all but try to keep this thread relatively clear ;)
Any questions PM me or reply in the first thread in the Photography section
This buy is not an offical BRISKODA organised buy and therefore BRISKODA, CANNOT be held responsible for any wrong doing that may occur.
I can also not be liable for any problems that occur when removing existing badges, fitting news ones, unsatisfaction with the final look once on your car, or if you do not fix them properly and they fall off! :rofl:
Cliff
Edited by PastyBoy
  • Replies 175
  • Views 45k
  • i quite fancy the normal badges but in black and silver
  • My pleasure Mr Roll! look forward to seeing them in situ! Have mocked up the attached - something for the hard core site supporters maybe :yes:
:orb_artis
If you have any luck with the mirror/chrome back and the green mate i could be in for 4 of the bigger
sorry again for the the awkward **** :orb_duh:
1. Imperator - standard 80mm x 2
2. robclubley - standard 80mm x 2 + Postage to NZ :D
3. Big_dave - standard 80mm x2
4. TaylorHawkins - custom 80mm set & 55mm f/b in black and white? :D
Edited by TaylorHawkins
4. TaylorHawkins - custom 80mm & 55mm in black and white
5. Bobjim - standard - 80mm x2
4. TaylorHawkins - custom 80mm & 55mm in black and white? :D
6. Taberoo - 80mm x2 Silver (not stainless steel) & black? + matching wheel caps
7. yegnold - 55mm x 4 (alloy wheel centres) - as first example
8. moose52c - 55mm x 1 (steer wheel cent) - 80mm x 2
9. Kablam - custom 80mm x2 (front and rear badge) Black on white
****UPDATE****
Just got off the phone to the suppliers and most colour options are available.
They do increase the price by £1 per badge though due to being produced seperately from the main run.
Supplier is putting together a material colour swatch for this time next week but hoepfully any options should be covered
They will however NOT be exact paint colour matches i.e. red will just be red not Corrida red etc
Edited by PastyBoy
10. AndyVR6 - standard - 80mm x2
I'm still trying to decide whether to go for these or not so came up with the following very quick photoshops to aid anyone like myself who can't decide.......
Dave.
Edited by WaveyDavey
11. Okeh -standard -80mm x1
xx
Want to change mine to black and silver
3. Big_dave - black and silver 80mm x2
12. Polo6n1600i - std 80mm x2
13. metz - std 80mm x2 custom 80mm x1 yellow and black custom 80mm x1 vrs caliper green and black.
13. metz - std 80mm x2 custom 80mm x1 yellow and black custom 80mm x1 vrs green and black.
14 Firefighter56 std 80mm x2 stainless steal and black.
15. MattC3156 - standard 80mm x 2
16. ORTA - Black/Silver standard 80mm x2
17. MudPuppy - Custom 55mm x 4 (yellow with black)
18. Birdwell L&K - standard - stainless steel with black 80mm x 2.
19. WaveyDavey - Standard 80mm x2.
Dave.
Bear in mind, any Octy 2 owners, that the grill badge is bigger than the boot badge.
Guest
