Help! My EPC (Emissions) or CEL (Check Engine Lamp) is on.
There's a very simple thing to check first: your brakelights. If they don't work, check the brake pedal switch. It's a common fault. Also have a look for anything obvious like a loose or failed HT lead, or an audible air leak if that's appropriate for your car.
Other than that, you really need to get your car scanned by someone with VAG-COM (VCDS), a VAS computer (the one dealers have), or a OBD-II scanner.
Of these, the VAS or VCDS/VAG-COM is your best bet as it can read and decode more faults from the car.
You have several ways of getting the car scanned:
* You can pay a Skoda (or other VAG) dealer. Typically this will cost at least £40.
* You can pay an independent garage. This will be a bit cheaper, but unless the garage specialises in VAG cars, it will probably only have a generic scanner.
* You can ask here in the VAG-COM and diagnostics forum. Look at the member map. If there's someone near you, send them a PM, and negotiate a price- which may just be a pint or two.
* You could obtain VAG-COM/VCDS or a code reader yourself. This can cost as little as £20ish for an ebay cable and a limited downloadable version of VAG-COM, but a fully licenced version (with full capability and support from Ross-Tech) costs more.
For later cars (Octavia II and Superb II), you need a CAN-capable scanner or a version of VAG-COM and appropriate genuine Ross-Tech cable that supports CAN-only cars.
A scan really is the only way to try to diagnose a CEL/EPC light, and often odd running problems as well. If you post the logs from the scanner on this site, someone will have a chance of solving your problem. Otherwise, it's just wild guesswork and you could be checking and changing things for ever.
  • 1 year later...
Emission Lamp On in Skoda Yeti may be a broken injection. Pay attention on this
  • 5 years later...
We recently had an EPC light issue in our 2012 Yeti 1.2 petrol. I came across this website when looking for a dealer to help fix the problem.
The car fault symptom was new, intermittent and resulted in the engine running in 'restricted' mode. This resulted in the Yeti running at max 30mph until it warmed up a bit (60 degrees approx) with the EPC letters lit up. Once the engine was warm the EPC warning disappeared and the car worked normally albeit with the engine management picture lit up.
Our local garage in Godstone (DD Services) have a device that showed an error code, they called me and said that the car system was showing an error code BUT they said it is very important to get a software upgrade before doing anything else.
Engine Code 10478-P334 charge pressure control actuator electrically malfunction defective.
Their fault finding had managed to clear this error and the car seemed normal but to be safe we took the car to Station Garage in Horsham who then tested it and upgraded the engine software.
So it seems that the original engine software was programmed to respond with an error when it got a signal from a sensor when in actual fact the engine did not really have a problem...I suppose that can happen as engines become more reliant on software and sensors...
Thankfully each garage charged for 0.5 hrs labour to do their work and no parts were involved. The Yeti is back to normal and we hope it stays like that.
