Cage Mod - revisited
Recommended Posts
See link for more details - http://briskoda.net/fabia-i/cage-mod-wow/94182/
Sure I have seen this detailed elsewhere but doing a search on the forum returns no hits, not even the above link??
Read about this some time ago and actually went and bought the grease from Maplins, then got sceptical so did not do the mod. Grease then sat in the draw for 3 months till I stumbled upon another post mentioning it so got out the grease.
I have a PD140 - Filled the MAF connector with the stuff and slowly pushed the connector back on, cleaned up the squeased out grease and away.
Definate improvement, smoother tickover and pick-up seems smoother and quicker - why did I not do this earlier, cos it seemed too good to be true - but it isnt - so thought I would give the mod a new thread and possibly bring it to a new audience.
Edited by Octavia5
clarification
Link to comment
Share on other sites
I bought a tube of the Servisol silicone grease today from Maplin, but I've removed my MAF connector and it's spotlessly clean and free of dirt. The connectors are gold plated on my PD170.
Given thar there's no muck in there to leak current across and that the connections are gold plated, can there be any value to this mod for me? Is the PD140 / 105 / 130 MAF connector not gold plated?
Link to comment
I gave it a try last evening, with another local brand of silicon grease (BTW the silicon based grease it was the most expensive of a whole group of different types of greases)on my PD170.
It didn't harm, for sure, even if my connector too was perfectly clean (at least at sight).
First I sprayed on both plug and receptacle some contact cleaner, then filled two times with grease.
Car seems a tad quiter, but time will tell...
Link to comment
I have heard that if you have gold connectors then you don,t need to do this mod as no affect will happen.Its the older models that don,t have this.My PD105 has gold connectors but my MK1 PD100 had old style connector pins and i did get a result from this mod.
Link to comment
Hi,
just thinking... given the silicon grease has insulation properties, it won't help better connectivity. BTW, gold plating is applied in order to avoid corrosion. So, if you have no gold plating the grease should prevent corrosion, but, even if you have gold plated connectors I wondered if it might eventually work in order to reduce some EMI eventually captated by the MAF connectors...? This way it might give some contribution to better fuelling.
It would be interesting to measure EMI/RF inside the engine bay...
Anyone? Chavdar, perhaps?
Link to comment
The grease is not there to improve conductivity between the male and female contacts, it is there to reduce the chance of tracking or leakage across the seperate connectors through an ingress of moisture or even damp air. By filling all the nooks and crannies with di-electric grease there is nowhere for the moisture and indeed air to go. The resistance of the grease should be alot higher than that of water or even air, this should result in a truer MAF signal being received at the ECU.
Has anyone greased their ECU connector too? - Oh, another job to do now!! :rolleyes:
Link to comment
This has reminded me, did this on my Fabia and noticed an improvement.
I've still got nearly a full tube of the stuff from Maplin from when I did the Fabia (I'm not gonna use it for anything else am I?!) so will give it a whirl on the 2.0T and see if it helps.
Steve
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
