Get it Ready For Winter
As J.R. says, I've never had a car with central locking. But hot water on windows does create problems on older locks. So I use WD40
Earlier in year to stop problems ( bit like Lee tieing lader to pole , before he went up it, rather than whinging after coming off).
  • Replies 208
  • Views 66k
  • Pfft. Winter tyre threads are so last year. We're all cross climate tyre threads now :-) Sent from my LG-H815 using Tapatalk
  • Bump!   Too soon
  • Cars all prepped again before some freezing weather hits.  Tyres checked for pressures, screen wash, anti freeze and oil, brake fluid and autobox level  Clean dry rubber mats in. No carpet ones.  Wind
Lee- almost been there and got the T shirt. One day I put ladder up, and tied it , but didn't see dog poo under bottom of one leg. Got off pole, to ladder ,with belt on and ladder went squiffy. Sort of saved by belt as I still had one leg on step. BTW- you should never criticise the old leather belt with MK1 tetra, as done properly it was fall prevention before you fell.
BUT it does pay not to throw out those front car mats. I keep the old ones in boot, for when I get a bit of snow. Older blokes ( and BMW drivers, take head, BMW folks need string to tie to bumper ). As BMW drivers do not rate highly on my list of brain bots, I'll explain. Tie string to old mat, then tie to a bit of car. place in front of rear wheels, and drive of. Once you get somewhere, you can stop and drive off, retrieve mats and put in boot.
  • 11 months later...
That time again.  Minus 9 screen wash ok until it is not.  Reduced to £3.50
Edited by Ootohere
  • 1 year later...
Used the last of the summer screen wash today and refilled the reservoir with some Sonax minus 20°C stuff. Normally I'd be swapping the tyres for the winters this weekend but I had all seasons fitted last year.
Might put some winter gear (gloves, blanket etc) under the false boot floor tomorrow).
Some advice on staying comfortable in the car in winter. Some advice is basic common sense but still worth a read.
Škoda Storyboard
No image preview
In winter, heat up your car, but don’t overdo it - Škoda...
Driving in winter not only requires increased attention but can also be a challenge for the health of both the driver and passengers. The right cabin temperature, sufficient hydration and regular m...
  • 10 months later...
That time again.
Edited by Evolution13
@Evolution13 I've never used RainX - got put off it ages ago when it talked of the criticality of cleaning the screen before applying it. Is the in your photo a single application version?
I use all sorts. Clean glass with white vinegar or meths if I don't drink it and rub with old newspaper then Rain X, fog X clear glass or whatever. Buff with old y fronts or a soft cloth. Treat window rubbers. Or not bother sometimes. Today I did most of that 3 times. Brae nicht the nicht, fair drawing in.
