OCC Installation
OCC Installation Part 1
Hi Folks, got round to fitting the OCC today and very pleased with finnshed results.:D
Thanks go out to Jaymd for organising group buy and Robclubley and westallc for there pics to help. :thumbup:
Pic’s of the hose used which is lined to stop oil breaking down the silicon.
Pic’s of the OCC , T piece, Joiner / connector
Bracket for OCC (already bent to allow fitting to slam panel), and hose clips at the ready.
Front plastic cover removed exposing the nuts and bolts to remove to allow slightly better access to the plastic hose.( I will refit this as like the way it covers the other hoses)
Carefully pull the bracket out the way and at the same time unclip the dip stick and also unplug the sensor that is underneath this metal bracket
Pipe highlighted to remove
Pipe removed.
Can see the goo in the T piece, cleaned this out as best as I could.
Remove the Y pipe.
DV removed and pushed to one side to expose the valve the new hose will be connected to.
Parts used to fit new hose to the T Piece. (note joiner cut down slightly to allow full insertion into T piece)
New hosed fitted.
Area highlighted for OCC to be fitted.
Fitted OCC with bent bracket to allow correct positioning of OCC. Bracket fitted underneath the slam panel to look more oem.
New hose connected to the Valve and DV refitted.
Refit the metal bracket removed earlier and remember to re plug sensor and re fit plastic cover.
  • Replies 69
  • Views 23.3k
  • OCC Installation Part 2 Pic�s of finished install.
  • And going back to what Lex has said, is the can 'sided' or is it just a loop?
  • Guest westallc
    Guest westallc
    yes mate it unscrews but doesnt come all the way off:thumbup: and yes it is sided cranck side and inlet side so the unit can work. there is no oil vapour going the inlet i have had mine on for a good
Pic�s of finished install. :thumbup:
Nice!
Cheers Rob.
Now whats next.:rolleyes:
Well for me - secondary air system removal - after my hols! :D
very nice well done mate :thumbup:;)
Looks the billy ****** mate, might try fitting mine tommorow :)
At least it's not just me who stick stickers on their engine bay :D
It was just asking to get something stuck on it.:D
Awsome mate, your a ledge, all these guides.
your in the wrong job unless you work for Haynes. lol
Haynes Modifications lol
billy
billy
Ha Ha, Cheers Billy, :thumbup:
If I am going to do a job it is going to be done well.
Support your forum is what I say.......
Now where's haynes phone number :rofl:
Excellent guide mate. Nice one :thumbup:
Only problem for me is that I can't use that hole on the slam panel, because the rod normally clips there :(.
It was just the right place and as I have bonnet lifters was going spare.;)
Nice guide and pics but would it not have been better to have the oil breather lines going to the side of the cc so the clean air feeds from above.
If it filled up the fluid could get into the intake as it is imo.
Looks very nice! is it one of these oil catchment tanks? what are the benefits of having one?
Hi there , thanks. Yes it is a oil catch tank. It basically filters the fumes and oil away from your engine and allows the fumes and crud to recollect in a seperate container ie a catch tank.
From here it is easily possible to drain this captured oil and either reuse it if you wish or cleanly disposed of.
Someone may have a more technical term but that's about it.
Talking of draining it off, has anyone undone the butterfly nut on the bottom? Feck it's tight!
I am not sure if the butterfly should come all the way off, but when it is loose the oil and crud just pours out. Maybe it is to stop folks loosing it?
So long as it is supposed to come undone, I'll try a bit harder. Cheers Mark!
and yes it is sided cranck side and inlet side so the unit can work. there is no oil vapour going the inlet i have had mine on for a good few months and my inlet track is 100% clean:thumbup::thumbup:
That's good news.:thumbup: This was one of the main reason for me to fit mine, to keep things clean.
How much liquid did you get out of yours so far?
Edited by Bowders1
not loads but enough......the inlet track is completly clean and so is the throttle body and front mount so i know its working well
and breath so much better:thumbup:
Yeah I've fiddled with mine loads! Ooo err. It was only finger tight, as you're not supposed to remove anything from the can. You literally spin the butterfly up the thread to open the valve, then spin it back down to the bottom to seal it again. If you force it undone the wrong way, you may end up removing the whole valve from the can!
I need to go buy my hose this week....
Got mine here if it helps.
19mm 3/4" Silicone Fuel & Oil Hose Flouro 1 Metre Blue on eBay (end time 17-Oct-09 15:46:14 BST)
