2664 Firmware Battery Drain - Update
Ok i decided to check which Can - Gateway i had installed in my car as i have no Battery Drain issues.
A lot of reports suggest you need a Revision L Gateway. Well you don't as Revision K works aswell as thats what i have
See Pic:
So for all those looking for a new Gateway you need K or above :)
Simples
Carl:thumbup:
Damn, i'll have to change mine as it's a revision F :(
Likewise...:(
I've got a Q on its way from Poland! :woohoo:
Does Pam know yet ?
I thought it would be safer to whisper, just in case
TOLD YOU THE 8 STEP PLAN WOULD WORK SIMBO :D
OOPS WERE WE SUPPOSED TO BE QUIET? :D:D:D
CARL:thumbup:
Shhhh... 8 step plan! :thumbup:
So what are the other seven ? I won't tell - honest - not like big mouth soulja boy
Hi All,
I'm Tim from Belgium.
I have a little qustion, my english is not so good, ill do my best!
You wrote: Revision K or above ..is that = revison ABCDEFGHIJK ? or KLMN ... ?
Thanks a lot!
Tim.
Tim,
that will be KLMN.....
Hi All,
Thanks a lot!
Tim.
As you own a Superb² you will not have these problems. From somewhere end of 2006 or beginning 2007 the rev will be K or higher (higher up the alfabet).
Hi All,
I have checked ... i have ideed a superb II en the VAG number is:
1K0 907 530 Q
I home mine, April 07, has the right version!
Will when it stops raining.
Not had chance to play with VCDS since getting it on my own car.
Hi Everyone,
I have the 1K0 907 530 Q canbus and firmware 266X but i stopt driving the car and shutdown the car and when i going a couple minutes later to my car i hear the DVD-drive reading from the RNS ?
Is that normal ?
Sorry but can someone explain this to me. I am going to buy a Colombus but have a very early mk2 Octavia vRS. I haven't checked the CAN gateway version yet but is the battery drain issue a problem with all versions of the Colombus or just the one with the latest firmware?
Ok So I will ensure that I get an older firmware version.
2700?
I think it's time you wrote a definative FAQ post for all that is Columbus/MDF3/RNS510 :thumbup:
