DSG Gearbox oil change
cng
Recommended Posts
Hi, I am just planning ahead , my 2007 tdi will be due a change of DSG gearbox oil a few months from now ( 40,000 miles ). It looks to be quite costly at the main dealers. Has any one changed the oil themselves or an independant garage ?
If so was it much cheaper ? I suspect the oil is costly and it takes 7 odd litres of it I am led to believe.
Link to comment
Share on other sites
Hi, I hate paying over inflated main dealer labour rates, but unless your independant has the VAG tool for removing/filling the oil and is familiar with the process I would bite the bullit and stick with the main dealer. The oil itself is also expensive, there isn't really a cheap way around it. The price in Ireland is approx. 200euros.
Link to comment
I did the change myself. Made my own tool..real easy for about £20 and bought 6 litres of oil from dealer for about £10 +VAT / litre.
In the end the DSG used less than 5 litres.
14mm allen key required to remove the DSG sump plug on my car. That cost another £6 from a tool supplier.
Giving DSG an enema !
Okay a quick update.... I made up my own DSG oil change rig. Used a drilled out DSG plug (bought from dealer) into which I epoxyed a plastic fitting. (ref pic).
It worked 100%, but was perhaps whole rig was over kill. I have been thinking what else would work almost straight out of the box.
No do not laugh or ask how I came by this, but caught a glimpse of this emena kit which looks ideal.
All that's needed is to buy a drain plug, drill it out for the barbed fitting on the plastic valve so it's a push fit and expoxyed to secure.
Viola... cheap deposable clean refill tool.
As required, pour each 1litre of oil into the bag.
To help oil flow more easily, let the 1 litre bottles sit in warm water for a several mins.
Use an infra-red thermometer to read the DSG casing temp.
This link will give you many interesting hours of reading on the DSG
VWvortex Forums: DSG and S-tronic Transmission Forum
New v Old Oil after 25.6k miles (first ever change from new)
My MK1 oil ring at work...
Edited by mrlapou
Link to comment
That all looks very easy...................if your name is McGyver !!
Link to comment
I've been quoted about £150 IIRC by an independent- I asked at my 30k service. The oil and filter is quite expensive.
Link to comment
Assuming, your company is eligible for a huge discount on parts and the job only take 40 mins at most using hoist and competent mechanic, £192 + Vat looks over the top. Local VW garage here uses trainees for such jobs incl cambelt changes. They are paid minimum wage of less than £8/hr !
Link to comment
I've just been quoted £151 (inc VAT) for a 40,000 mile DSG service.
That's at the Skoda dealer. No one else seems to be willing to touch it with a barge pole.
I even tried an independant garage specialising in Volkswagens, which will also service Skodas, but they wouldn't touch it. They won't touch a DSG gearbox on a VW either.
Link to comment
Guest Fabia 12v
£192inc not plus
Book time is 0.9hrs (@ £110+VAT P/H)
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
