Rear Washer not working
Over the recent cold spell the rear wash on my VRS Fabia stopped working. Hunted through the forum and while there were plenty of threads on the subject I couldn't find one with "an idiots guide" attached. To correct this here is a pictorial guide on attaching the pipe at the bottom of the washer resevoir located at the front passenger wheel (RHD). Apologies if it's been posted before, I couldn't find it and a picture paints a thousand words as they say.
First turn the steering as far as it will go to the right and take the key out of the ignition.
Remove the 3 torx screws indicated by the red lines in the picture below.
Next gently pull the plastic inner guard back towards the wheel.
This lets you see the pump and the offending disconnected pipe circled in red.
Push the pipe back onto the nozzle and replace the 3 screw from the first picture. Job Done!
cheers ill keep that in mind :thumbup:
Excellent guide, well done. :thumbup:
Nice pics. :thumbup:
I should have taken some pics last weekend when I looked at the other 3 places the pipe comes off. Ap0gee guide was very useful, but pics are better. :yes:
top notch matey :thumbup: Thought this was a lot harder than it actually looks!
Edited by Confused_Cheese
  • 1 year later...
Thanks for the info Doghandler :thumbup: . Just fixed my washers in five mins thank's to this thread. :D
Those pipe keep popping out for me. Had the car two years and I've had to reattach those pipes half a dozen times! lol
Lol I will keep that torx key in a safe place then ;) Anyone know a permanent fix?
Edited by RAPTURE
  • 7 months later...
Tie Wrap it on ? :p
Are you going to do any of the other places with pic guides ?
Just wondering as the pics make a big difference!
There's a connection in the engine bay that used to pop on mines all the time.
  • 3 years later...
I'm gonna have a gander at this tomorrow
Post on hereabout washbottle mix. It needs to be at least 50% mix .Other post on hereabout a Skoda fix, which I believe was something akin to a tie wrap /clip. On the other hand ,there's a school of thought that pipe popping off is a safety device to save the motor if the pipes freeze.
This forum helped me find the connection that had popped of in the rear p/s pillar
I knew the carpet was getting wet.thought it was rear door seal.so went ahead and fixed that.
Then it was only cos rear washer stopped working i realised how was getting in.
Now screen wash is 50/50 mix of halfords -20 stuff. ☺
