BRISKODA.net: Hums when I switch off - BRISKODA.net
Page 1 of 1
Hums when I switch off Rate Topic: -----
#1 User is offline   Mr Ree
  • Briskodian
  • PipPipPipPip
  • Group: Members
  • Car:Skoda Fabia vRS, AX GT and Corsa Combo van
Posted 31 January 2010 - 08:50
I've done a search but couldn't find anything relating to this.
Every time I turn the engine off ( Fabia vRS) I get a fairly loud buzzing/humming noise.
I can even feel the vibration under my feet now.
It's obviously not going to go away and fear something is eventually going to fail.
Sounds like an electrical fuel pump firing up, but surely not when shutting the engine down?
Anyone else had or got this?
#2 User is offline   vRSLen
  • 4X4 Driver
  • PipPipPipPipPipPip
  • Group: Members
  • Car:RAV4 D4D 2.2. Fabia II Sport 105. Bandit 1250
Posted 31 January 2010 - 08:58
I thought they all did it? The ones I have had did....
#3 User is offline   Mr Ree
  • Briskodian
  • PipPipPipPip
  • Group: Members
Posted 31 January 2010 - 09:03
Well I've owned a Fabia for nearly five years now, but have only noticed this noise within the last 6 months tbh, unless it's just my hearing becoming more acute as I get older p'raps? :S
#4 User is offline   Static
  • Briskodian
  • PipPipPipPip
  • Group: FREEDOM
  • Car:Fabia VRS
Posted 31 January 2010 - 14:50
Mine has been doing this for the last 4 months... thought it may be something to do with the colder weather?
Car is just over 3 years old
#5 User is offline   MoggyTech
  • Briskodian
  • Group: Members
  • Car:Fabia VRS LE / Morris 1000 Traveler
Posted 31 January 2010 - 15:37
Anti shudder valve operating, it's normal. Early ones are built into the EGR valve and vacuum operated. Later ones on BLT engine are electrical and make a clicking sound. Vacuum control modules sometimes fail, try listening to the black box behind the coolant expansion tank when you switch off. If it's buzzing loudly, it may be about to fail.
#6 User is offline   TDi Vrs
  • Briskodian
  • PipPipPipPip
  • Group: FREEDOM
  • Car:SKODA FABIA vRS
Posted 31 January 2010 - 16:52
my black box buzz's for about 10 secs after engine turned off
#7 User is offline   thealienfromura
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Fabia VRS silver
Posted 31 January 2010 - 17:03
Mine does the same. done it since i have had it, about 2 years now.
They are a sealed unit and cost about £100??
Someone correct me if im wrong
#8 User is offline   VRSBUZZ
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Fabia 1.9 Tdi Elegance Estate
Posted 31 January 2010 - 21:03
All the 1.9 diesels hum for a few seconds after shutting down. It is the fuel pump and power steering pump shutting themselves down thats all. You may also hear a click when shutting down which is a valve fitted to part of the vac system. On mine the pipe fell off this valve and it used to shut down very violently. A bit of glue from a glue gun re-secured it and it shuts down smoothly again.
#9 User is offline   Mattcooper79
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Golf gti
Posted 31 January 2010 - 21:35
I had mine replaced by Ali @ unit 18. He said this is not normal and should not be buzzing at all. I have had the new box for about a year now with no buzzing at all. When Ali plugged the car into the diagnostics he found fault codes. He was able to reproduce the buzzing through the computer.
Your right the part is approx £100 and fitting will be pence.
Mine was getting gradually worse,
Dont know if that helps thing!!!
#10 User is offline   Mark_vRS
  • Briskodian
  • PipPip
  • Group: Members
  • Car:Fabia vRS
Posted 06 February 2010 - 21:05
Mines been doing it alot recently maybe due to colder weather? But anyway, i work for a VW dealer so i got one of the lads to plug the old girl into the diagnostics and came back with no faults but, he did say it was that black vacuum box making the noise.
#11 User is offline   Tom1964bus
  • Member
  • PipPipPip
  • Group: Members
  • Car:07 Fabia VRS SE No - 830
Posted 22 February 2011 - 16:48
mines now doing this, whats the score with it? can i cause other damage? other than the little buzz when its turned off mine seems to drive as normal :(
Share this topic:
Page 1 of 1
Fast Reply
Loading
