Retro-enabling s/w related functions on Yeti
Hi Folks,
I was thinking on the way to work today about how so much of a vehicle is controlled by software these days and was wondering if things like the hill-start control and 4x4 button are simply a matter of enabling the appropriate functions in the ECU etc? Obviously the off-road button needs a physical button, but I am sure the wiring loom was there behind the dash for it. So, in theory its a matter of plugging in a button and enabling the functionality in the ECU.
The same way that one can enable the MDI or bluetooth functions after the hardware is fitted. Except for anything that's transmission/ engine related I don't believe there would be a difference between those models with the function and those without as its all interconnected.
Clearly it needs someone with good knowledge of the VAG ECU/ s/w etc but I am sure there is a lot of the car that can be turned on after its built.
Any thoughts? Anyone tried it?
I have paid for the off-road button to be fitted to mine, but I am struggling to justify £85 for the hill-start if its simply a tick in the box within the s/w?
How about the lights (boarding spots) built into the mirrors. There is a blanking plate on the underside of each mirror, is the wiring behind it?
tom
tom
Indeed. I am sure there will be lots of things that can be retrofitted.
Need to examine the exploded parts lists and then find someone with a good understanding of the vehicle control systems.
