Alternator Replacement
Undo battery leads, or at least the negative one and pull lead away from battery
Remove engine cover, the one with the badge on it, not the rocker cover
Remove the earth lead and connector block from rear of the alternator
Undo the viscous cooling fan, allen key from behind in the alloy case it attaches to, you will need to over tension the drive belt to stop it slipping while you undo the key
Using iirc a 17mm spanner, lever the tensioner over the other way to slacken the drive belt and pull it off the alt pulley, then remove the fan bolt
Drop fan into fan housing
Undo the two bolts holding the alternator and remove it
Replace alternator and refit the fan
Put the drivebelt back on and tension it so you can tighten the fan key back up fully
Leads back on the alternator
Final checks and put the cover and battery back on.
Edited by Supurbia
  • 14 years later...
Hello from your description it sounds like you removed it from the top. I'm pretty sure on a MK2 it can only be done from underneath. Can you please clarify as I'm about to change mine and your way seems much easier
