Westfalia towbar info
:thumbup: Have a look at this site for excellent info on fitting thier towbars and electrics inc coding for CAN bus (Skoda fitted ?) just enter the make and model of your car B) cheers - Stuart.
http://www.westfalia-automotive.de/index.php?id=10&L=1
Edited by sparky2
  • 2 months later...
:thumbup: How to add extra cables into drivers side fusebox (thanks to 'anewman') see here - http://www.my-gti.com/601/addition-of-extra-circuits-to-the-volkswagen-golf-jetta-passat-eos-scirocco-rabbit-fuse-box , The repair cables are available priced each cable, in packs of 5 which are double ended see pics -
Both of the above connectors are for the smaller fuse connector in the side door fusebox !
if you want the connectors for the normal blade fuse I went to a VW dealer -
cheers - Stuart
Edited by sparky2
