Lidl car polisher - any good?
http://lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_8400.htm
found this and wondered if it was any good. i would like a machine polisher and wondered what the difference was between this and other more expensive models, such as the ones the pro detailers use.
Useless mate. A proper DA has a 550 watt motor and velcro backing plate to take different pads. CYC are doing an offer on the DAS6 complete Menzerna kit for £130
I would guess the Lidl one might be OK at applying / buffing wax, but I very much doubt it will be any good at all for polishing and paint correction,
This was my thought! I was in there getting a jack & axle stands yesterday and took a good look around the polisher. Sure it seems OK for the money, but if it needs anything serious, it just wasn't going to cut it (no pun intended.....) :D
Thats what I thought anyway, but thanks for confirming it. I am just too tight to spend £130 on a polisher for my car! SWMBO says that there are more important things to spend money on! :thumbdown:
She's wrong, but don't tell her I said that :rofl:
Calling a DAS6, etc a "polisher" is a bit of an understatement :D They are so much more than that :D
In the grand scheme of things the polisher will do a job but it all depends on your requirements I guess, if you want to apply a glaze or light polish then I am sure it will be fine but as stated it's not going to complete any swirl removal................ :thumbdown:
I see Dodo Juice have now released their own machine to challenge for the DA sales:
http://www.elitecarcare.co.uk/product_info.php?manufacturers_id=47&products_id=712
Edited by Baker21
Looks like a rebadged DAS6 to me :D
Yeah they are all pretty much the same machine just branded differently, good old Dodo Juice have worked well to come up with that name for it's machine....... :rofl:
If cheap matters, see this thread over on detailing world....
http://www.detailingworld.com/forum/showthread.php?t=83874
it's quite a bit to wade through unfortunately. In short though you need a random orbital sander with a velcro backing pad of about 125mm, with a variable speed of around 4000 to 12000 OPM, and at least 400w motor. You then need some pads, for example http://www.elitecarcare.co.uk/menzerna-135mm-polishing-pad.php and polish and you should be away.
The Lidl one will be just a rotary type thing and will be useless. I have a similar machine that I doubt I'll ever use again.
Yeah i bought that lidl one here in ireland thinking it would be alright like but it was completly ****, any kind of pressure applied to it and it would slow right down, i brought it back and got my money back :D
