This is worrying ............ URGENT
Recommended Posts
I've just inspected my new vRS CR DSG that was collected yesterday and note that the front red calipers have been 'reworked' - see pictures. Both front calipers have had substantial material removed top and bottom (possibly with a grinder) and no attempt made to protect the bare alloy afterwards. Can anyone that has collected their new vRS recently have a look to see if this is normal because I'm concerned this could be a safety issue. I'll contact Skoda and the dealer when I've had some feedback.
http://i766.photobucket.com/albums/xx303/peter999_photo/vRS%20Caliper/DSCN0047-1.jpg
http://i766.photobucket.com/albums/xx303/peter999_photo/vRS%20Caliper/DSCN0048.jpg
http://i766.photobucket.com/albums/xx303/peter999_photo/vRS%20Caliper/DSCN0049.jpg
http://i766.photobucket.com/albums/xx303/peter999_photo/vRS%20Caliper/DSCN0050.jpg
thanks
Peter
Link to comment
Share on other sites
http://i766.photobuc.../DSCN0047-1.jpg
http://i766.photobuc...er/DSCN0048.jpg
http://i766.photobuc...er/DSCN0049.jpg
http://i766.photobuc...er/DSCN0050.jpg
thanks
Peter
Ooer that doesn't look right. I'll have a look at mine in the morning...
Bob
Link to comment
thanks
Peter
TBH mate and apart from image one all other pics are blurred so I personally can't tell..........Better images would be good.........
Link to comment
thanks
Peter
Nope,
They are all like at at the moment, when I took off my wheels to clean, & had a good look at the machined surface & you can see where the caliper has been held for machining. The calipers are painted before the bores are machined, it may well be that they have just changed the machining procedure.
The dealer will not have a clue to be honest, neither will SUK
Good Luck
G
Link to comment
thanks
Peter
Actually looked at image one and can't see an issue apart from no paint at that point. Are you saying that the metal has beenground also? The caliper itself is solid cast iron so it would take a fair bit of abuse anyway.....
Link to comment
thanks
Peter
Actually, would you have noticed if they had not been painted in the first place.......? :mmm:
Just an observation....
Link to comment
Appreciate the prompt responses and sorry for the poor pics - I was in a bit of a panic to take some for the forum. .
A considerable amount of material has definitely been ground away and they not just holding marks.
I've emailed the dealer with some pics ............
Link to comment
It looks like someone's just picked up an angle grinder and taken a chip out of the caliper :S Weird!
Shouldn't the ridged body of the caliper continue running with it's ridges until it's flush to the end of the caliper, if you see what I mean?
Link to comment
LOL, I too can confirm it's normal. I finally cracked and went outside with a torch. It was just the angle of your photo and the cleanliness of the unpainted metal on the caliper made it look worse than it is. :rofl:
Edited by wega3k
Link to comment
It's quite normal Engineering practice to paint castings before machining as it is difficult to paint after machining due to masking problems . Also the important pad seating, piston seal areas, etc are machined to the correct dimensions instead of being covered in an indeterminate thickness of paint . I would be more worried if every thing was painted !
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
