MP3 CD's for the Dance Stereo
Hi, i was woundering if people have made mp3 cd's for your fabia with the Dance stereo. Can you put them into folders etc cause i want to put multiple albums on one cd and dont want each song muddled up.
Thank you in advance.
Simple answer yes you can, took me a little while to work out, but what I do is copy album folders from the iTunes music file, (only if they are in mp3 format, if not itunes can convert them). Then get a blank CD-R or CD-RW and when the windows explorer wizard comes up make sure you format it as a data CD, not a music CD as this won't work. Copy all the folders across to the disc, finish it off and your done. The radio will order the folders by name a-z, so in my case the albums are in order, the tracks will stay in the correct order for each folder. Make sure you don't put any folders in a folder, it won't find them. I find it can usually take about 11 albums.
Hope that helps.
Hope that helps.
The method you are using must be copying the albums in W.M. Fomat (Windows Media) as using MP3 format you will only get about 6 or 7 albums on a CD-R Disc.
Windows media tunes take up a lot less space.
BoB C.
BoB C.
I can get 8 folders to an 800mb CD in MP3 format. I just used Windows Media Player to rip and then burn to CD in MP3. You can adjust the quality and size of the MP3 files before ripping and burning in the 'options' menu for best, or low quality of anywhere inbetween. But you prolly know that anyway.
Edited by Estate Man
Are the fabia 2 stereos ISO plugs?
