BRISKODA.net: DSG lurch - BRISKODA.net
Page 1 of 1
DSG lurch DSG sometimes lurches when starting in Park Rate Topic: -----
#1 User is offline   timjfw
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Octavia 2.0 DSG
Posted 20 March 2010 - 07:10
Has anyone with a DSG ever had the car lurch forward with a loud clunk when starting the car in park? It almost feels like the car is in gear and the clunk is quite loud. Noticed it mostly in very cold whether. Have started putting the car into neutral to start instead of park. Should I have always been doing this? Was taught to drive in a manual where you obviously start the car in neutral but I thought starting in park was ok ?
This post has been edited by timjfw: 20 March 2010 - 07:10
#2 User is offline   ChrisRs
  • Dvě Skoda rodiny
  • PipPipPipPipPipPip
  • Group: FREEDOM
  • Car:Octavia II FL vRS + Fabia II vRS
Posted 20 March 2010 - 07:12
I start in 'Park' and not had a problem.
#3 User is offline   cjb
  • Briskodian
  • PipPipPipPipPip
  • Group: FREEDOM
  • Car:Leon TDI DSG or Lupo 16v Sport
Posted 20 March 2010 - 07:50
It shouldn't lurch in Park. It's odd that it's ok In N though, as P is essentially neutral with a mechanical lock to the output.
This post has been edited by cjb: 20 March 2010 - 07:51
#4 User is offline   Yetiflute
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Yeti 2.0L 170HP Elegance Muscovado/Gobi
Posted 20 March 2010 - 08:20
My DSG is new (3 weeks old) and about 700 miles. Certainly no symptoms like that. No clunks, no lurches, utterly smooth at all times - including stop/start traffic. I always start it in Park position.
#5 User is offline   Octavia1Z
  • German Briskodian
  • PipPipPip
  • Group: Members
  • Car:1,9 TDI DPF
Posted 20 March 2010 - 08:52
I may be wrong, but haven't I read in our german forum that there is some software update available curing this? Mind you , I don't have DSG so I didn't read this too carefully.....but I am pretty certain it was to to with jumping and clunking during acceleration.....
#6 User is offline   dan_the_v8man
  • Briskodian
  • PipPipPipPipPip
  • Group: Members
  • Car:A4 quattro 2.0TFSi
Posted 20 March 2010 - 09:14
My Passat DSG used to do this till it had the mechatronics unit replaced
#7 User is offline   m0bov
  • SurreySkodarian
  • PipPipPipPipPip
  • Group: FREEDOM
  • Car:Octavia vRS FL Petrol DSG
Posted 20 March 2010 - 13:14
Is the handbrake off by any chance?
#8 User is offline   Evening Star
  • Uber Member
  • PipPipPipPipPip
  • View gallery
  • Group: FREEDOM
  • Car:Octavia Elegance 1,8TSi DSG
Posted 20 March 2010 - 13:18
Not had this problem with mine so far, been as good as gold.
#9 User is offline   gilesk
  • MadridBriskodia
  • PipPipPipPipPip
  • Group: Members
  • Car:Octavia 2.0 PD DSG Combi
Posted 23 March 2010 - 16:34
I found that if you park up and put in in park and then dont apply the handbrake it rests on the gears, then when you take it out of park into drive you get a clunk. Park and then Handbrake to take the strain helped me.
#10 User is offline   mikeoz
  • Briskodian
  • PipPip
  • Group: Members
  • Car:FL Vrs + New Fab Vrs
Posted 23 March 2010 - 17:36
Have a new vrs dsg and not had that. Also had a number of other autos with other brands and that is not a normal thing for the box to do. I would get it looked at.
Mike
#11 User is offline   Birdwell L&K
  • Briskodian
  • PipPipPip
  • Group: FREEDOM
  • Car:06 Octavia L&K 140DSG
Posted 23 March 2010 - 19:41
I am on my second dsg Octavia, and never had this at all.
#12 User is offline   110ivan
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Octavia 1.9 TDI PD
Posted 26 March 2010 - 16:41
Apparently there are some 35,000 DSG gearboxes across the VAG group with problems,on Skoda's this effect the Octavia II and Superb II.Your main dealer should know about this.Normally the symptoms of gearbox problems are that you're driving along and the gearbox engages into neautral on it's own.Part of th gearbox called the mechatronic unit needs to be replaced,see one today,quite a big expensive lump full of valves and solenoids,if you are having problems go to your dealer to have it rectified as there is quite a demand for this part and you could be in on the waiting list.
#13 User is offline   Minimoke
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:2009 Octavia Estate Elegance 2.0 TDi PD DSG and 2010 Fabia SE 1.2TSI (85)
Posted 26 March 2010 - 21:58
Rough shifting and clunking from the box MIGHT be the mechatronics unit. VW DSG boxed cars in the USA have been subject to a recall over this. What year is your car? I think this only affects 2007-2009 cars.
Loss of drive is a very different issue. This is also subject to a recall in the US, and also to a limited number of Octavia II and Superbs II's in the UK (see VOSA site). This has nothing to do with the mechatronics box - its due to faulty temperature sensors.
Your dealer will be able to check if your car is subject to a recall for item (2) and hopefully to test for (1).
This post has been edited by Minimoke: 26 March 2010 - 21:59
Share this topic:
Page 1 of 1
Fast Reply
Loading
