Octavia Mk I - Convenience system components
The Octavia Mk I convenience system is made up of all or some of the following components, depending on model and optional equipment:
Convenience System Control Unit (J393)
Electrical equipment in the doors as follows:
- Electrical central locking with SAFE function.
- Power windows with obstruction protection.
- Electrically adjustable and heated exterior mirrors.
Also:
- Off delay for interior light.
- Monitoring and switching off all interior and luggage compartment lights as a protection against discharging battery.
- Sliding roof closing function as a result of a closing command from outside.
- Radio remote control for anti-theft alarm system and central locking.
Convenience system components are located as follows:
1. Central control unit (J393) - located behind the bottom part of the dash panel on the driver's side.
2. Connector - located in grommet between driver's door and A pillar.
3. Driver's door control unit (J386) - attached to power window motor.
4. Driver's door lock.
5. Connector - located in grommet between door and B pillar.
6. Rear left door control unit (J388) - attached to power window motor.
7. Door lock.
8. Lock mechanism for boot lid - located below trim panel of boot lid.
9. Fuel filler flap lock.
10. Door lock.
11. Rear right door control unit (J389) - attached to power window motor.
12. Mechanism for sliding roof.
13. Interior light.
14. Door lock.
15. Connector - located in grommet between door and B pillar.
16. Front passenger door control unit (J387) - attached to power window motor.
17. Airbag control unit - located on the transmission tunnel and accessible after removing the left footwell trim panel on the driver's side.
18. Connector - located in grommet between door and A pillar.
Guest
