ASR Light comes on after 10 minutes
Hi,
This is my first post here. Hello everyone!
I have a 2006 fabia vrs 1.9 tdi - 34000 miles. Next service is due 25 May 2010.
Last week i noticed the ASR light turning on exactly 10 mins after starting the engine. It doesnt matter if the car moves or not, it still comes on after 10 mins and clears when you turn it off. This happens every time.
I got RAC out to read the codes and it showed up: 18265 load signal error message from ecu.
Theres no ABS light or engine light.
The car is running as normal. ABS works whether the ASR light is on or not, and ASR seems to work until the light comes on (i.e. if i accelerate hard on a slippery surface the light tempoarily flashes and the power cuts as normal). Nothing else to report from it's history.
I really hope someone can help! Thanks in advance.
You need to read the other codes and post them here.
That code means that there are other codes that will indicate why the ECU cannot communicate load information.
Thanks for the reply.
Skoda want £100 just to do a diagnostic so I really dont want to take the car to a dealer at this stage, so was thinking I might invest in a code reader.
Could anyone recommend an error code reader that's reasonably priced, that would get me all the codes now and in the future?
Here's a few I thought might get me the codes:
http://cgi.ebay.co.u...em=180480736252
http://cgi.ebay.co.u...E:X:AAQ:GB:1123
Could anyone advise on these or others?
Ps i've got a laptop if thats a cheaper way?
Hi strange this one, i have been having same problem for a few days. Dont know about the exactly 10 mins thro, but i do know it comes on whatever, cant see a pattern.......and if i turn off ignition and restart it goes out......for a while then returns
maybe ill take to local skoda taxi repair place and ask them................
There might be a member near you both with VCDS software who would be willing to scan your cars for you. Have a look at the list of members below who have VDCS and/or other DIY diagnostic software or tools.
http://briskoda.net/...cds-owners-map/
Thanks for your help. Fatty5000 has come to my rescue - he has vagcom and is just down the road. I will post the error results later tonight.
Ok I have some error codes - Thanks to Fatty5000 - very much appreciated!
I've read a few other threads about faulty wiring, but i DO get the battery light come up on the dash when i turn the iginition on, which then goes out as normal. The fault codes were cleared, but the ASR light has come on again after 10 mins.
Any help would be really really appreciated.
Here we go...
VCDS Version: Release 908.2
Data version: 20100326
Thursday,01,April,2010,20:06:20:28932
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
Mileage: 55470km/34467miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NJ
Component: 1,9l R4 EDC 0000SG 7331
Coding: 00102
Shop #: WSC 13765
TMBWU46Y964561043 SKZ7Z0F3424730
1 Fault Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ASR.lbl
Part No SW: 6Q0 907 379 AG HW: 6Q0 907 379 AG
Component: MABS 8.0 front H04 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002229
Shop #: WSC 13765 000 00000
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 18
Reset counter: 151
Mileage: 55110 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0840
No fault code found.
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25738
Shop #: WSC 13765
1 Fault Found:
01117 - Generator Terminal DF Load Signal
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 0S AIRBAG VW51 0009
Coding: 12371
Shop #: WSC 13765
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y0 920 972 S
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 28401
Shop #: WSC 13765
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 003D GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 13765
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 60 Komfortgerát 0002
Coding: 00018
Shop #: WSC 13765
Address 56: Radio Labels: 1U0-035-156.lbl
Part No: 6Y0 035 156 E
Component: Radio YD5 0015
Coding: 00403
Shop #: WSC 13765
End ---------------------------------------------------------------------
Edited by wiffola
Alternator fault or alternator wiring fault. Possibly alternator voltage regulator or dirty slip rings/brushes.
many thanks moggytech. What would be my next step? Could I take that info to a local mechanic or is it safer to go to Skoda dealer?
One other question: the battery seems fine at the mo. Is this going to damage the car in anyway if I keep driving it until it's service in late may? It could save a few bob if I time the service and diagnostic together.
I would get it looked at ASAP. If it's the sense wire, the battery will most likely go flat when you least expect it. If it's the main load wire, the alternator could be wrecked if it tries to output a voltage into no load.
I had the same problem on my 54 plate Vrs,turned out to be a broken wire from or around the alternator,seems to be a common fault.
Thanks for your replies everyone. My plan is to book it into my local VAG specialist asap, give them the error codes and point them in the direction of the alternator and it's wiring.
I'll post my results.
Thanks again everyone.
Had mine back to local garage. Only reading after full diagnosis was a slightly high output from alternator, and some damaged wiring under bulkhead, wiring replaced, fault ligjht still continues emoticon-0101-sadsmile.gif
Amyone also had new discs and pads recently got the problem.................or is it the mouse in the garage eating my bulkhead felt!!
Normally caused by broken wiring at the connector plug down low in front of the gearbox. Easiest to find if viewed from below. Quite a common area for wire breakage. I normally extend the wiring a couple of inches when repairing, skoda seem to have the wires very tight
Problem solved!!!
Bought some ramps for £10 off of ebay. Ramped up at the weekend just to take a look before taking it to the VAG specialist and just as many people have suggested, there was a broken wire coming out of the connector into the alternator!
There was just enough wire poking out of the connector to get a mini junction box on there and reconnect the wire. Only one of them had snapped. Taped her up (within an inch of it's life!) to stop anything breaking again, started her up, left it 10 minutes, and NO asr light!
So a massive thank you to everyone who helped me out on this, especially Fatty5000 who initially scanned it to get the error codes.
Here's the link that I followed to repair it, in case anyone else in a similar position http://www.seatcupra.net/forums/showthread.php?t=209472.
Back to problem free motoring and the pleasure of cancelling the repair by the VAG specialist on tuesday!
Cheers guys!
  • 2 months later...
Just my 6 pence worth, had the same problem (ASR Light coming on after 10 minutes turning the ASR off). Had my FAB over the pit the last couple of evenings and spent 3 hours looking for the culprit wire after changing the oil, nothing obvious. After a lot of tugging and pulling and prodding the broken wire was actually inside the connector housing, the connector being located to the right of (when viewed from the front) of the bottom of the gearbox (you need the under tray off, and it jacked up to spot). It was the black connector (not the brown one adjacent) with a purple wire and blue wire inside. Only problem is, these connectors are sealed one piece plastic affairs and I can't get inside it to splice in a new bit of wire....... Going to have to take a trip down the scrap yard tomorrow and find a connector with the 2 wires still attached off a VAG car, shouldn't be a problem then hopefully fixed!! If not I'll have tourettes again.
So reckon I'll have saved about £150 if I took it to Skoda for a diagnostics test and had a monkey playing around with it. Hope my little experience saves someone some £.
FAB
  • 5 months later...
Had same problem of asr light switching off after 10 minutes and sure enough as wiffola found both wires snapped on plug as shown in the seatcupra thread.
Have repaired wires and will update if it cures other problem as well which is pas takes time to start working on engine start up, with no oil visable maybe this will sort this problem also as have read that battery alternator wireing can be the cause apart from pump and other sensor failure.
Thanks to all keep up good info like this.
just like to say thanks to FAB, i had same fault on 56 Fabia VRS, it indeed was a broken cable as he described. superb infomation there. managed to put a connector in and it now runs a treat.
again, many thanks,
Big Al
Edited by al nix
Although it doesn't apply to PD engines, the traction control light will come on if the diesel fuel injection pump timing is wrong, and in particular too far advanced. In this condition the ECU cannot properly control the timing.
but that wouldnt flag a code for alternator load and from the few i have fixed its always been the connector on the gearbox that has either broken 1 or both wires...................................................
I have had the ESP - ABS light problem for a few days. When I investigated, I found that the black connecting plug near the gearbox (the culprit identified on this thread), had a broken blue wire. This was not initially easy to spot, as it had broken right at the plug. I went to my local VAG breaker to get another plug and was told to take one from a recovered Fabia wiring loom. Would you believe that when we looked at it, this plug had the blue wire firmly fixed, but the green/pink second wire was broken about 1 cm from the plug end! Anyhow, enough to crimp a connection. All put back together and a test drive showed.... both bl**dy lights still showing after 10 mins running. At this point I lost patience, went to my local auto-electrician (Stonebridge Auto Electricians) and had them run a diagnosic check. Faulty brake switch, shown in two diagnostic fields. Bo**ocks! New switch £10.15, diagnosis 3x that! I'm wondering what will be next, as they usually come in threes.
And I still havn't fixed the back door leak........
An earlier post asked if a car with this fault was safe to drive. My 06 plate Fabia 1.9TDi has had this exact issue for about a week. I have only drive short distances in it since then but have a 400 mile round trip to do this weekend. I can't get the car seen by anyone (or really look at it myself) until next week. Does anyone have any advice?
I'm not 100% sure, even after reviewing these posts, what this wire actually connects and why it takes 10 minutes to come on.
  • 6 months later...
I just wanted to thank every one in this thread and update....found this info and pointed me in right direction !
I had this same problem (04' VRS) - ASR light coming on after 10mins.........gave the Skoda tech a print out of this thread - he then checked the fault code and went straight to the wiring loom from alternator to ecu and found broken/corroded wires - all fixed in 1hrs labour (negotiated with them £60 for diagnostic + 1hrs labour, all done for £60 inc VAT!!). Light now not coming on so fingers crossed its now sorted !
Thanks !!
  • 1 year later...
I seem to have this same fault but cannot after a lot of searching find the connector in question. I have an 03 octavia TDI. Can anyone point me a bit further please.
  • 3 months later...
Bump
Can anyone post a picture/diagram of the suspected area?
