Numpty alert - what's the easiest way to measure my front strut diameter ?
It could be 50 or 55mm - how can I measure which one it is ?
It will most likely be 55mm.
I just used a ruler offered up against the strut. It's quite easy to tell if it's 50 or 55mm,
If your not 100% sure with Harrys method, wrap a tape measure around the strut, if it measures 173mm its 55mm diameter, 157mm is 50mm. :thumbup:
Thinking of lowering it then Bryan :yes:
Might be :o
Thanks to you and Harry for the response :thumbup:
Yeah, divide the circmference by pi (3.14 basically) then you have the diameter. :thumbup:
