Cornering Fogs Speed
Hey
Just had cornering fogs enabled the other day and what im wondering if the speed below when they come on can be reduced, currently its 40kph and to be honest i think thats a bit high as driving around town or roundabouts behind someone the fogs are winking away goodo
i think would be better if the only came on below 15 or 20 kph, so if anyone knows if this can be done or where to change this would be great thanks
Dallan
I would like to ask you something. How you enabled this function? I will buy Skoda Octavia elegance and this funtion cost 110€. Is this only function or it is also different fog lamp?
Thank you for answere.
Bye
Trdonja
Hey
Dallan
No there isn't a way of lowering it
Bye
Trdonja
If you have a relatively new octavia (2008 onwards) then you can enable it with VCDS or a Dealer can.
Carl,
Does this mean I could get them turned on in my 2008 L+K Estate?
Tom
I got mine enable with VCDS and it uses the fog lights as you turn left or right the light alternates between the fog lamps,
to be honest im not entirely sure its of any benefit after having it for a while now, as it is hard enough to notice a difference as i dont think the fogs are bright enough along with the original issue of the speed below which they are enabled
i think i will get em turned back off the next time its on a vcds :wonder: :wonder:
But thanks for the replies :thumbup:
EDIT : Cornering Lights How To Here Octavia-vrs.com
Edited by Dallan
Carl,
Tom
Yes I enabled them on my 2008 L&K Estate :thumbup:
Thanks Both.
Tom
can you do this on a 2007 "56 plate" Fabia vRS?
Nope :)
