BRISKODA.net: Can VCDS scan for codes on other marques? - BRISKODA.net
Page 1 of 1
Can VCDS scan for codes on other marques? Rate Topic: -----
#1 User is offline   BigW
  • Moderator
  • Group: Moderators
  • Car:Noddy Car
Posted 30 July 2010 - 14:22
Renault for instance?
Ta
I have read it somewhere but cant see how to do it.
#2 User is offline   Chris_55
  • Briskodian
  • PipPipPip
Posted 30 July 2010 - 16:52
It probably can using the generic OBDII function, this is only available using a genuine Ross Tech lead and the later versions of the software.
#3 User is online   bearthebruce
  • Briskodian
  • PipPipPip
Posted 02 August 2010 - 00:02
For 2008 and newer CAN based cars, the answer is yes. Generic OBDII scan should work.
Prior to 2008, it depends on which flavor of OBDII the OE used, There are two methods out there and VCDS only supports the method used by VW/Audi. We never intended VCDS to be a generic OBD scanner but when VW/Audi began using the generic OBD information in their tech bulletins and so on, we added the capability so that users of VCDS could follow the tech info published by VW.
#4 User is offline   BigW
  • Moderator
  • Group: Moderators
  • Car:Noddy Car
Posted 02 August 2010 - 09:15
Thanks Bruce, Thatll be my problem, its a 2006 Scenic, when I connect up it says that it is not OBDII Compatible.
Share this topic:
Page 1 of 1
Fast Reply
Loading
