Rough Road Pack
The Rough Road Pack option provides additional protection to areas of the Yeti particularly underneath that could be damaged if the vehicle is driven over rough ground or on gravel roads.
There are two specifications of this pack;
Production start to 01.08.10
02.08.2010 to present
Highlighted below are the principle areas with additional protection underneath, based on the initial specification offered (Skoda publicity image)
Additional note:
Yeti's fitted with the either version of the Rough Road Pack, have what the manufacture describes as a reinforced brake fluid distribution system and hand-brake cable. The rear rigid brake pipe lines to the left and right rear brake hoses, plus handbrake cables and associated rear brackets, therefore have different part numbers to those normally fitted to the Yeti.
Brake Cable - 1K0 609 721 BB
Brake cable bracket (11mm) - 1K0 609 651 C
Brake line to hose LH - 1K0 614 741 AH
Brake line to hose RH - 1K0 614 742 AJ
Original specification Rough Road Pack; production start to 01.08.10
The following photos were taken of a RHD 4x4 SE which was built WK42/09 (MY2010)
The main component is a steel protective 'skid plate' under the engine bay (this replaces the standard noise insulation panel).
Note the rear of the skid plate is attached to the cast aluminium assemble carrier.
Additional stone chip guard panels are fitted over the triangular section at the rear of the standard under-body trim panels attached either side of the central tunnel for added protection to fuel and brake pipes (Note: these additional panels appear to have only been fitted to some RRP equipped Yeti's)
Plastic stone guards are fitted to both rear lower wishbones (axle beams), covering the front and lower face of the beam and protecting the frontal area of the coil spring.
A protective foil film is fitted to the rear doors to guard against paint chipping (a number of owners have reported this to be a problem on vehicles without the film).
Associated part numbers for original RRP (production start to 01.08.10)
Engine Protection
Skid plate petrol engine = 1K0 018 930 L
Skid plate diesel engine = 1K0 018 930 J
Damping diesel engine = 1K0 018 997
Carrier for under-body guard (front 1.2TSI) = 1K0 018 936 G
Carrier for under-body guard (front Diesel & 1.4 TSI) = 1K0 018 936 F
Carrier for under-body guard (front 1.8TSI) = 1K0 018 936 D
Carrier for under-body guard (rear) = 1K0 018 926 B
Bracket mount LH = 1K0 018 965 E
Bracket mount RH (All except 1.2TSI) = 1K0 018 966 E
Bracket mount RH (1.2TSI) = 1K0 018 966 F
Plus various nuts and bolts
Floor-pan
Under-body trim panel LH = 1K0 825 201 AC >> 01.08.2010 (standard across range not part of RRP)
Under-body trim panel RH = 1K0 825 201 BF >> 01.08.2010 (standard across range not part of RRP)
Additional protection added to the rear part of the above panels;
Stone chip guard LH = 1K0 825 001B
Stone chip guard RH = 1K0 825 002B
Hex panel bolt 5x16 = N 103 546 02
Speed nut = N 909 591 01
Additional parts to rear wishbones
Stone chip guard LH = 1K0 511 533 D
Stone chip guard RH = 1K0 511 534 D
Hex bolt M6x12 = N 905 298 03 (Qty 2)
Riveted cap nut M6/0,5-3 = N 909 203 01 (Qty 2)
Spreader rivet 8mm = 8E0 825 267 (Qty 2)
Door foil film
Protective foil LH = 5L0 807 905 B >> 01.08.2010
Protective foil RH = 5L0 807 906 B >> 01.08.2010
Note; the above additional protection package (except door foils) is also fitted to the Octavia II Scout but as standard equipment.
Rough Road Pack specification amended; WK31/10, 02.08.2010 to date (highlighted by Onesque).
The following is a visual guide to the new specification Rough Road Pack; photos taken by Onesque of his RHD 4x4 Elegance built October 2010, MY2011.
Steel 'skid plate' is replaced with similar but supposedly lighter thermoplastic component (This update to the engine shield also effects Octavia Scout; thanks London Les)
Additional stone chip protection panels deleted completely, due to a change in part numbers to the under-body trim panels (Note; Octavia II Scout not effected by this part of the update).
Note also: Protective foil film fitted to the rear doors has become standard across range to resolve paint chipping issue (WK45 November 2010).
Associated part numbers for revised RRP (02.08.10 to date)
Engine Protection
Skid plate petrol engine = 5K0 825 901 (Golf VI component)
Skid plate diesel engine = 5K0 825 902 (Golf VI component)
Damping diesel engine = 5K0 825 225
Bracket mount LH = 5K0 825 921
Bracket mount RH = 5K0 825 922 or 5K0 825 922 A or 5K0 825 922 B (depending on model)
Socket head bolt with inner multipoint head M8x18 = N 701 170 01 (Qty 4)
Socket head bolt with inner multipoint head M10x30 = N 910 758 01 (Qty 3)
Riveted cap nut M10= N 904 480 04 (Qty 3)
Hex nut shouldered M8 = N 907 611 03 (Qty 1)
Hex panel bolt 5x16 = N 909 747 01 (Qty 8)
Hex collared bolt M12x1,5x80 = N 909 747 01 (Qty 2)
Floor-pan
Under-body trim panel LH = 1K0 825 201 AD 02.08.2010 >> (standard across range not part of RRP)
Under-body trim panel RH = 1K0 825 201 BH 02.08.2010 >> (standard across range not part of RRP)
Door foil film
Protective foil LH = 5L0 807 905 C 02.08.2010 >> (now standard across range not part of RRP)
Protective foil RH = 5L0 807 906 C 02.08.2010 >> (now standard across range not part of RRP)
Original steel plate (left) compared with the new thermoplastic design (right), as viewed from above looking down into engine bay.
More photos of the latest pack; 'borrowed' from the French Forum :)
Note the new thermoplastic skid plate, plus the new steel plate assembly carrier that replaced the previous cast aluminium version also on 02.08.2010 (see earlier photo).
TP
  • 2 years later...
It looks like the 5K0 825 90x (5C6 825 90x) thermoplastic engine protection has been withdrawn from production. I was trying to order one recently but suppliers refuse to supply it. The only engine shield that is listed in the current catalogues is a steel one - 1K0 018 930. The latter seems incompatible with the previous mounts though.
Edited by briskycat
  • 3 months later...
Just checked mine (bought today, new) which has the factory-fitted Rough Road package; the engine protection is thermoplastic.
Having a plastic "sump guard" is not a problem. Many rally cars now use the same, and they are often stronger (and lighter) than the old aluminium equivalent.
  • 2 months later...
Can you just expand on that. With a 2 year old Yeti can you retrofit some or all of the Rough Road Package ? Thanks
Edited by Masai
I cannot see why not but costly; would advise speaking to a dealer but one that knows what their on about.
TP
Having damaged some of the rrp panels when I went offroad a year ago, it cost about £200 for the replacements, but it was only the panels under the offside, and the dealer had problems finding the right one, it seems like they have changed the design a few times.
  • 11 months later...
Here are a couple of photos of my new Octavia III 4x4 estate which has option 2UF fitted (Chassis with increased ride height). As you can see it is also fitted with the thermoplastic sump guard and underbody protection so this appears to be essentially the same as the RRP (option 2UB).
Octavia 3 Sumpguard
The picture above shows the sumpguard.
Octavia 3 Underbody Protection (nearside) towards rear axle
The picture above shows the underbody protection on the nearside towards the rear.
The picture above shows the underbody protection on the offside.
Octavia 3 4x4 Rear Diff
Just for interest, the picture above shows the rear diff on the 4x4.
Edited by nickcoll
For some reason I can't further edit my post above, but one comment I wanted to add to the note after the picture of the rear diff is that this picture also shows the exhaust running under the rear axle, and this is the lowest point under the car. The actual clearance under the body is probably more than 150mm over most of the car, maybe 160mm or more, but this is reduced by the exhaust which is the lowest point. I wonder whether the Scout will be any different in this respect?
From the pics your car has an RRP, note also the plastic guards on the rear suspension beams.
Exhaust could have maybe be better designed by Skoda but there's a lot of bits back there to have to work round.
Thanks for posting,
TP
Read this with interest. I've recently acquired a 2010 cr170 elegance and just noted the car has the following option code
2UB SWP Rough-road design
Is this the 'rough road pack' referred to above or is it something else? I guess I could have a look underneath but it's cold, dark and wet out there and I'm very comfy in my armchair!
The Rough Road Pack - Yeti Outdoor is option code 1SK - Additional engine and transmission guard and underbody stone guard.
  • 2 years later...
1
Agreed, it's the one area that's let me down whilst off-roading in my Yeti. The silencer needs a sloping skid plate at the front so that it helps the silencer ride up and over centre-of-the-road obstacles. Instead, it tends to catch on rocks etc and pull the whole exhaust system backwards thus disengaging the front support arms from their rubber mounts. This causes the exhaust to hang lower and rattle when going over bumps. It's fairly easy to fix but a pain when you have to jack up and work under a muddy vehicle.
