VCDS scan, egr fault
I bought the lite version of VCDS from eBay as every now and then the EML has come on for about a day then gone off again !
So, I have done a scan with 1 fault showing and it said: EGR system regulation range exceeded.
What exactly does that mean ? I did the stutter fix a few weeks back now with the 9mm gasket could it be related to that ?
Yes, 9mm gasket often throws out a CEL light and EGR fault code. Options are to drill the gasket out to 12mm or turn down EGR flow rate with VAGCOM.
Thanks Moggy I thought it would need drilling out.
I've read about drilling it to 10.5mm but would 12mm be better ?
11mm is the absolute minimum to guarantee no CEL.
Thanks again moggy :) 12mm it is then
