OEM Bluetooth any ideas on these fault codes?
ollybroad
Recommended Posts
Have had the oem bluetooth retrofitted for a couple of months and it has been great. I've not long had my VCDS and notices whilst trying to get another retrofit to work i've got faults on my BT.
I have had a search on the web and it looks like the antenna fault is because i'm using a cheap chinese one.
Not sure about the other 3.
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 B HW: 5N0 035 730 B
Component: J412 8502
Revision: 00015000 Serial number: 0000B7A144740
Coding: 0010037
Shop #: WSC 00000 000 00000
VCID: 277329E5EF85
4 Faults Found:
02791 - Telephone Baseplate (R126)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Mileage: 7498 km
Time Indication: 0
Date: 2003.14.07
Time: 09:47:46
01524 - Antenna for Telephone
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Mileage: 7498 km
Time Indication: 0
Date: 2003.14.07
Time: 09:47:46
02794 - Cell-Phone Prep. Control Head (E508)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Mileage: 7498 km
Time Indication: 0
Date: 2003.14.07
Time: 09:47:46
02749 - Control Module / Control Head for Telephone (J738)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Mileage: 7498 km
Time Indication: 0
Date: 2003.14.07
Time: 09:47:47
Link to comment
Share on other sites
Forgot to add I have this error on my navi.
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 3T0 035 680 A
Component: RNS-MID H05 2684
Revision: AB001001 Serial number: --------------
Coding: 000004020001008100
Shop #: WSC 73430 790 00000
ASAM Dataset: ------------------------- ------
VCID: 2E7DDCC1C07F
1 Fault Found:
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Mileage: 7498 km
Time Indication: 0
Date: 2003.14.07
Link to comment
Had no issues with the BT been working fine. Found out the coding was incorrect changed it from 0010037 to 0020227 and now all the fault codes have gone.
Hi Olly,
I'm looking into retro-fitting BT to my Columbus fitted Octavia at the moment. I've searched every forum on BT coding and have found a lot of conflicting info. What coding info did you get?
Mainly interested in where your code 2 under 'Communication Type' came from.
Any info would be appreciated as I don't want to end up with a half a*sed installation with a 'nearly but not quite' compatible module.
According to VCDS the coding is as follows:
00?0xxx: Communication Type
0 = Display-Data-Protocol (DDP)
1 = Operating and Display Protocol (BAP)
00x0?xx: Installation List
1 = Diagnostics via CAN
2 = Multi-Function Steering Wheel, Diagnostics via CAN
3 = Head Unit (e.g. RNS-E), Diagnostics via CAN
4 = Multi-Function Steering Wheel, Head Unit (e.g. RNS-E), Diagnostics via CAN
00x0x?x: Language (Voice Control)
0 = Voice Control OFF OR via external Device (e.g. RNS-E)
1 = German
2 = English (UK)
3 = French
4 = Italian
5 = Spanish
6 = Czech
7 = English (US)
8 = French (CA)
9 = Speaker dependent (Voice Commands inactive, Acoustic Name Selection active)
00x0xx?: Language (Display)
0 = No Display
1 = German
2 = English (UK)
3 = French
4 = Italian
5 = Spanish
6 = Czech
7 = English (US)
8 = French (CA)
Link to comment
Hi Olly,
1 = German
2 = English (UK)
3 = French
4 = Italian
5 = Spanish
6 = Czech
7 = English (US)
8 = French (CA)
0 = No Display
1 = German
2 = English (UK)
3 = French
4 = Italian
5 = Spanish
6 = Czech
7 = English (US)
8 = French (CA)
Mine is the GSMIII rSap model so my coding is different from the coding you have posted. What model are you getting?
Link to comment
It's a toss up between the newer 1Z0 035 729E or the older 1Z0 035 729B.
I have a pre FL car with a 3T0 RNS510 with FW 2764. So as I understand it with the 1Z0 035 729E I can have all the functionality except Maxidot or with the 1Z0 035 729B I can have Maxitot but risk having issues with the RNS510 not displaying the phone functions correctly.
Having done a lot of research here and on other sites I think the obvious answer is to get the 1Z0 035 729E, keep the RNS510, and chuck out the pre FL Octavia! Either that or give up on the whole idea, put the Stream back in, and blow the dust of my Tom Tom 730.
Best Regards,
Mark
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
