Fitting alloys on your Fabia
Fitting alloys 100 members have voted
  1. 1. Do you think this is helpful?
    • Extreamly Helpful, Thanks.
      86%
    • Slighly Helpful.
      12%
    • Still Confused. (Please post why)
      1%
    • It Was Rubbish. Take it away.
      1%
Please sign in or register to vote in this poll.
Awesome post :thumbup:
Really informative and should defo be made a sticky
cheers
cheers
Thanks mate, wasn't sure if it was needed or not though. I've had a loa of people PM me about fitting wheels so thought if i could put the info in one place it will be easier. I dont mind people PM'in me by the way haha
How do i decide what colour to refurb them in??
And what tyres should i put on them?? :giggle:
Seriously though top work pip - couldn't really ask for more but i have a feeling it wont stop the "will these fit" threads :dull:
One suggestion might be a "these will bolt straight on" list ie Octavia mk1, Fabia Mk2, Leon Mk1, VW Golf Mk4 etc etc
Edited by PastyBoy
Should now be sticky...
Thanks alot.
As to what colour to refurb them.. do them pink :dull::giggle:
Another issue is wheel bolt types. VW use radius seat bolts and aftermarket wheels often use taper seated wheel bolts. Bear in mind that an aftermarket alloy wheel could be thicker or thinner for the section where the wheel bolt shaft goes through. Meaning a different shaft length of wheel bolt required.
Pretty sure I have a spare set of tapered wheel bolts of standard length if you need the Jason, if they are tapers seats dont use the radius bolts, they wont tighten up correctly.
I have a set of seat leon alloys (mk 1) they ave an offset of 42 and are 7jx16h2
Will i need to get a set of 10-15mm spacers for these?
I know they will sit in a bit but as they are 7j rather than standard 6.5 im thinking they may not need spacers?
Im currently on my iphone so not easy to do it for you, but if you put the standard wheel speck into the 'offset cslculator' link in my first post and your new wheels it will calcilate how much the wheels will move over standard. If you get stuck drop me a pm.
  • 3 months later...
This post saved me asking some daft questions. :thumbup: Thanks.
  • 2 months later...
I love it when I go from ignorant to informed...... great post, sticky for me
Thats what its here for mate :-)
  • 2 months later...
Hi can i put on mi Fabia 1.9 TDi estate 51 reg. alloy wheels from audi A4 205-55-16"
And will i pass MOT later on with it?
  • 4 months later...
Great post. Thank you!!
  • 4 months later...
hi guys, got a problem with fitting wheels, recently got some 16' 5 spokes from an audi, there 205/55/r16 tyres now all of them fit fine except the rear left side which rubs against like a triangular shaped part of the shell on the rear of the arch, any ideas guys?
Rob, the profile is too big on the tyres. It probably ought to be 45 rather than 55, hence the rubbing.
  • 10 months later...
Will I be able to put Fabia Mk.1 RS 16" stock alloys on my 2010. Fabia 1.2TSI?
My wheels are 15"x6 ET43. And the RS ones are 16x6.5, ET42 or 32? Cant find the exact info anywhere. :|
Yes they will fit. No problems.
Thanks! :beer:
Can't believe some one has voted that this is RUBBISH!
I appreciate the effort that's gone into this
Thanks op
Will 17 inch fit on my fabia that has 14 inch?
Yes with 205/40 17 tyres they will have the same rolling radius as your 14" wheels + tyres
Thankyou, I will be looking for some alloys then
Just checked + the rolling radius would actually be slightly bigger but if u follow this link below it will barely make any difference to the speedo reading.. but they will def fit.. all mk1 fabias are the same regardless of what wheels it came with from the factory ;)
http://www.willtheyfit.com/index.php?width=185&aspect=60&diameter=14&wheelwidth=6&offset=38&width2=205&aspect2=40&diameter2=17&wheelwidth2=7.5&offset2=35&Submit=Submit
