DRL tail lights on Octavia II FL
With any DRL's activated (separate lamps in front fogs, low-beams, front fogs) on my Octavia 2 FL (1.4 TSI, Elegance, July 2009) the tail lights (rear lights) stay off.
I've seen O2FL's with the same equipment (and coding) having the tail lights on when DRL's are on.
Seeing the same coding behaving differently on cars with the same equipment leads me to believe it has to do with Byte 18 of module 09 (BCM).
How can I enable/disable (*at will*) my tail lights when DRL's are on?
Here's an AutoScan from my car:
VCDS Version: Release 10.6.0
Data version: 20100630
Tuesday,31,August,2010,16:35:23:48106
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBJ21Z1AC(six digits removed)
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAX) Labels: Redir Fail!
Part No SW: 03C 906 016 D HW: 03C 906 016 C
Component: MED17.5.5 3981
Revision: LCH02--- Serial number:
Coding: 0000072
Shop #: WSC 31414 790 00001
VCID: 206132E38AAB
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.lbl
Part No SW: 1K0 907 379 AQ HW: 1K0 907 379 AQ
Component: MABS MK70M 0105
Revision: 00H32001
Coding: 0016641
VCID: 8127D767A161
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AK HW: 3T0 907 044 AK
Component: Climatronic H14 0302
Revision: 00004001
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_SK35.rod
VCID: 7BDB258F438D
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0537
Revision: 00103 AB
Coding: 46180AB8B80508C000080001150081EC034100AE400089605C0440000000
VCID: 3245C8ABD447
Part No: 1Z1 955 119 C
Component: Wischer 11050 22 0601
Coding: 00D7B7
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q2 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2DHEAJ
Coding: 0020786
VCID: 3D5FEB971D19
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CE HW: 1K0 953 549 CE
Component: J0527 055 0111
Coding: 0000501
VCID: 77D339BF7FA5
Part No: 3T0 959 537
Component: E221__MFL-URO H07 0011
Coding: 00000128
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 B HW: 1Z0 920 843 B
Component: KOMBI H21 0109
Serial number: 00000000000000
Coding: 110B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3753F9BF3F25
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 0222
Revision: H16 Serial number: 4020K095080620
Coding: E9807F06000202001302
VCID: 66ED64FB280F
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H21 0109
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: 3753F9BF3F25
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2107
Coding: 0004342
VCID: 76CD34BB78AF
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 68 2901
Revision: 00H15000
VCID: 2F43C1DFC775
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004342
VCID: 48B18A4342DB
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 008 0062
Revision: 0H001001 Serial number: SKZ1Z2I8242386
Coding: 050004000001
VCID: 3147C7A7D141
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 31414 790 1012545
VCID: 3245C8ABD447
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 334BCDAF2B5D
End ---------------------------------------------------------------------
Disable the DRL's mounted in the front fog lights, and enable Scandanavian DRL, this gives you dipped headlights and rear lights whenever the ignition is on.
If you want rear lights on, don't select North American option - this only gives front dipped headlights, and then only when the handbrake is off.
Mike
To my knowledge, there are no Scandinavian/NAR options in the documented coding of VCDS 10.6.0 for my BCM. This is a Facelift model. In case I'm wrong, please point to the appropriate couple of bytes. Thank you.
My initial question still stands:
I don't know exactly where the option is without plugging a facelift in, but on a facelift Elegance 10 plate I had a look at a few months ago, I'm sure the Scandinavian was an option, I remember it because I was asked what the difference was over the fog light mounted extra bulbs.
OK, I checked. VCDS 10.6.0. There is no description with the word "Scandinavia" anywhere in module 09 coding. I double-checked all 30 bytes. You're talking about a different BCM.
Revision: 00103 AB
VCID: 3245C8ABD447
Coding: 00D7B7
Sorry for repeating myself, but my initial question still stands:
VW/Skoda changed the entire scheme on how the light related codings work on the newer models, in addition there is now the difference between Daytime Running Lights (DRL) and Permanent Running Lights (PRL). So activating PRL instead may be the option you are looking for... In addition you may want to ask your dealer to update your BCM to Software Level 0575.
The only option in my 09 concerning "PRL" is "Permanent Running Light (PRL) via Low Beam active".
When I enable this option (and at the same time disable the "separate lights" option), the following occurs:
Light switch at 0 (off) = Front Low Beams turn on (as DRL), all tail lights stay off.
Light switch at 1 (side lights) = Front Low Beams turn off, front parking lights turn on, tail lights (including license plate lights) turn on.
Light switch at 2 (low beam) = Front Low Beams turn on, front parking lights stay on, tail lights (including license plate lights) stay on.
When I enable this option (and at the same time leave the "separate lights" option enabled), the following occurs:
Light switch at 0 (off) = Separate lights (additional small lamps in front fogs) turn on (as DRL), Front Low Beams turn on (as DRL), all tail lights stay off.
Light switch at 1 (side lights) = Separate lights turn off, Front Low Beams turn off, front parking lights turn on, tail lights (including license plate lights) turn on.
Light switch at 2 (low beam) = Separate lights stay off, Front Low Beams turn on, front parking lights stay on, tail lights (including license plate lights) stay on.
Testing the above two cases, I noticed no difference between 92% "DRL dimming" and 100% "DRL dimming".
However, when "DRL dimming" is set at 20%, the difference between "Light Switch at 0" and "Light Switch at 2" is noticeable.
During my tests, the "DRL dimming" setting affected *any* DRLs enabled; even all 3 at once (separate, low beams and fogs). In any case, all tail lights stayed off.
...So activating PRL instead may be the option you are looking for...
So, unfortunately, "activating PRL instead" is not the option for me...
When I ask the dealer for an update (not any time soon), I'll try the same thing. I don't expect much change though...
In the meantime, any other suggestion?
Thank you very much for your help.
We (Norway) get the new cars delivered without tail lights on when running with the DRL's on and light switch in either "auto" or "0". The tail lamps (when using DRL's) can be activated using a function in the dealer diagnostic equipment. I don't think activating tail lamps alters coding, but that it is more of an adaption??
This could change, and UK dealers might have different software on their diagnostic machines, but I do it all the time with the software i have on "my" VAS 5051B. I used basis CD 18.00 until today, and updated to 18.01.01 today.
I have not checked if the function still exists with the new software installed on the VAS5051B.
Hope you get it sorted! :yes:
Thanks for helping JonA!
Using "your" VAS 5051B, can you reverse the procedure? I mean, if you have activated the DRL tail lamps, can you deactivate them again?
Assuming it's an adaptation channel (and not some Byte 18 value changing and then returning back to 00), perhaps I could compare adaptation channels before and after the procedure. I'm thinking renaming the Labels folder and perform an AutoScan with Debug Level 2 (Type #1 Map). Then take the car to the dealer and ask to enable DRL tail lights. Then perform an AutoScan with Debug Level 2 again, and compare the files.
Sebastian, is there anything else I should do besides renaming the Labels folder?
edit:
JonA, I case you check the function still exists with the new software (18.01.0) please let me know. Thank you.
Edited by johnjohn
Yes, the procedure can be reversed using the same function. There is also a choice between right hand drive and left hand drive cars in the programme, so my guess would be that this function is present in UK VAS testers as well.
And yes, the function is still there after I updated the software in the VAS tester :thumbup:
Great, thanks! It's good to know that at least it's possible to activate/deactivate it at the dealer. Then maybe I can compare the channels/coding. Unless of course someone finds it earlier and posts. :yes:
...There is also a choice between right hand drive and left hand drive cars in the programme, so my guess would be that this function is present in UK VAS testers as well.
I'm not really interested in UK VAS testers though; I live in Greece. ;) But I guess it's the same everywhere...
Hi!
johnjohn, it is true that you can activate rear light at the dealer. But I can also say, that you won't find any change in adaptation or coding. I did the same :-) :-) the change is made directly in EEPROM. You could do it by yourself, but you need special software for EEPROM changes :-) and the knowledge where to search appropriate byte.
Also left/right hand drive info is written in EEPROM.
Hi!
Yes I completely agree, after using the VAS to code the 09 module, you will see 00 in byte 18 after it's done. However, I have one additional comment...
On the US Gti (and similar Jetta models, 1K/AJ/5K) equipped with Xenon and PRL coding, the Fogs as DRL's coding does just that. The Front fogs can act as DRL's either with or without the normal headlights.
http://forums.vwvortex.com/showthread.php?4743553-VCDS-MKVI-MK6-Platform-Handy-Coding-tweaks
But, we had some feedback about all of the exterior lighting running as DRL's when this bit was modified on RoW vehicles that use a different Byte 18 coding. I want to say there was a '10 Australian Eos, '10 Seat Altea, and I'm sure I missed one or two in there. The discussion starts here:
http://forums.vwvortex.com/showthread.php?4743553-VCDS-MKVI-MK6-Platform-Handy-Coding-tweaks&p=65096862&viewfull=1#post65096862
Some Byte 18 reference again and the source of the coding chart dimitrisTSI pointed out :
http://forums.vwvortex.com/showthread.php?4743553-VCDS-MKVI-MK6-Platform-Handy-Coding-tweaks&p=65746832&viewfull=1#post65746832
If you already have this sorted with dealer coding, that's great but if not please see what happens with this Byte 14 tweak:
46180AB8B80508C000080001150083EC034100AE400089605C0440000000
Hi Dana. Sorry for taking so long to reply.
I haven't yet been to the dealer and hopefully it won't happen any time soon.
I did try this coding in the past, but I tested it again just to make sure. As expected, my front fogs *and* my separate lamps in the fogs became DRLs at the same time. Still no tail lights when DRLs are on.
As stated before, my O2FL can have *any* combination for DRLs at once (separate lamps, front fogs, low beams, just one of them, any two, all three). On any DRL combination, the tail lights remain off.
Any other suggestions?
I really like having my tail lights off when DRLs are on. I don't want to change that. I want to know how I can revert it back, in case an upgrade at the dealer turns them on. As JonA confirmed, it's good to know that at least it's possible to deactivate them again using VAS. However, I still wonder how I can do it using VCDS.
dimitrisTSI (from your tweaks thread) has his tail lights on and wants to turn them off. He has the "luxury" of knowing what the initial value of Byte 18 is, so he can try different "scenarios" and always be able to revert back. I can't do that because I have no initial value to rely on...
  • 1 year later...
I have an OctaviaII FL 1.8tsi Scout. I have activated the DRLs via VCDS. No matter what combination of front lights I choose as DRLs, the tail lights remain always on. I wonder if someone has found how to activate/deactivate the tail lights when the DRLs are switched on. Personaly, I prefer the tail lights off when the DRLs are on. I hope someone has found a way to do it via VCDS!
I had the same issue and got mine reconfigured at a dealer. A friendly dealer who thankfully did not attempt a loot my of my wallet :)
  • 8 years later...
I have activated the rear lights as DRL in my own car. I have used VCP (Vag Can Pro) and VAGHelper.
