OIL WARING LIGHT help
#1
Posted 09 September 2010 - 23:36
in as it was just above max.. however its been fine ever since the service.. i turned the car off and checked the oil and its still a little above the max but only slightly.. i started it back up and te light ent out so i drove home and it only camed on when i went into boost.. any ideas??? im going to drain the oil out tomoro to see if tht helps ?????
cheers luke
#5
Posted 10 September 2010 - 08:52
just replaced mine with a new one £9.41 inc vat from skoda.
http://img.photobucket.com/albums/v77/b19fur/vrs/IMG_0520.jpg
http://img.photobucket.com/albums/v77/b19fur/vrs/IMG_0518.jpg
#8
Posted 10 September 2010 - 09:36
chicken_eyebrow, on 10 September 2010 - 09:10, said:
I'd heard this. Has anyone had a blocked strainer that hasn't had the sump replaced? I was thinking about getting mine changed at the next service but it cost around £150 - £200, but not sure if its necessary?
#9
Posted 10 September 2010 - 09:40
I guess it's something you might need to be careful about if you buy an ex job car as most of those will have had the sump torn off and replaced at least once in their lifetime.
This post has been edited by chicken_eyebrow: 10 September 2010 - 10:25
#10
Posted 10 September 2010 - 09:54
#11
Posted 10 September 2010 - 10:04
really glad i did this as it would definatly killed the motor pretty quickly they way i drive it, so a word of warning lads it is worth checking even if you appear to not have the problem.
Doesn't take long to do really either
#12
Posted 10 September 2010 - 11:56
madmike01uk, on 10 September 2010 - 09:36, said:
take it to a local garage with a lower labour rate, i did mine on my drive from start to finish in less than an hour
oil £32
pick up £9.41
sealant £6
#13
Posted 11 September 2010 - 21:13
#14
Posted 11 September 2010 - 21:15
Help
Add Reply
MultiQuote
