Multi media interface fitting instructions
http://www.epc.net.pl/manuales/MA-460_INTERFACE_RNS510.pdf
I have just got mine through the post and here are the fitting and wiring instructions, hope to be watching Corry next week in the taxi :thumbup:
Could this be made a sticky please
Very interested to see how you go with this.
Any chance you can detail all parts, where sourced from and any fitting photos/hints/tips if and when you get it going?? B)
getting it fitted tomorrow hopefully I will get some picks whilst its been done
Does this unit just work with the MFD or will it work with the Bolero as well?
Quite interested in this one too.
Could not get photos, but you just remove the Columbus, and the ash tray, to remove ash try leaver up gear stick cover underneath there are 2 screws
splice into the pins required as in the diagram connect up the box, then wire in DTV box to the fuse box, and connect up to MMP run Ariel cables up side pillars along with remote control sensor, installation took about an hour
re fit everything turn on Columbus and nothing, it needs coding to turn on TV function :no:
Installer could not do it as his vag lead was knacked, so all that's required now is to get it coded at Chathams in Edinburgh, unless someone wants some beer tokens, any offers from someone in the Edinburgh area???
Edited by skippy41
Bummer :(
If you could keep us up to date on things if and when you get a chance to get it coded :)
Bummer :(
If and when it works pics will be posted of it working,
Got it booked in for Thurs afternoon but they will let me know tomorrow if there will be any more problems, if there are will be selling it as I need a tv to watch while waiting on jobs from the rank and the chinky unit is looking promising :no:
Edited by skippy41
PICT0014.jpg[/img]
Success at last :thumbup::thumbup::thumbup:B)B)B)
Edited by skippy41
Well done :thumbup:
You know you need to give a comprehensive walk through now :wonder:
Whats the aerial looking like, think you said up your windscreen pillars? How's reception when parked, any problems? Are you getting all freeview channels?
Enjoy :yes:
Well done :thumbup:
Enjoy :yes:
Aeriel, on far left, same on drivers side, depending on where I am I can receive all the channels and a clear picture, if in the town it all depends on the buildings and the only place I need it it does not work, as the aerials are facing away from the mast direction, but should work with an outside aerial or 2, can receive radio on the move no problem, just need to find 2 very high gain magnetic aerials now.
I think I can now claim the title of having the first MFD RNS510 TV unit in an Octy in the UK :thumbup:
